my fuel pressure control solenoid makes some weird sound On my 92 Vr4 . like switching on and off 10 times a second.
It does this also few secs after i turn the engine off untill the Fuel Pump Relay klicks.
Am getting seriously flooded spark plugs also. Has anyone experienced this before?
I tried to Disconnect the Vacuum Hoses from the fuel pressure controle solenoid to the fuel rail and then i got some serious Blasting and Back-fire (under load not parked) at around 2500 + RPMs,
After that test drive i pulled the plugs And Got carbon covered spark plugs instead of gas covered sparks Before.
Need some info on this before I look for parts because they are rare here.
Fuel Pump Relay
