Both of the headlights on my 92 will not pop up. The lights actually come on and both work.
I've changed the switch near the instrument cluster but no effect. Is there a fuse or a connector I can check? I'd swapped the engine harness (but not the fusebox harness) but i'm not sure if that would make a difference.
