I'll try to get my hands on another comp checker. Until then I'm going to block off the brake booster and everything else and see if that helps the vac as the brake booster is OEM.
See, I'll be up all night as I cannot sleep. This whole thing is bothering the hell out of me.
With the car 100% cold, the vacuum reads 10hg and once the IACV starts to switch as the car warms up it goes to 15hg.
ok...did another compression test today with some depressing results.
Cyl Compression
1 165
2 160
3 90 dry / 130 wet
4 155
5 162
6 160
thats why its back firing out the plenum. see if you can measur the depth of the valves from the top of the head, if the valves on #3 and lower than the rest then your going to have to pull the head. just get a light and look into the port of that cylinder too just see if you got light down there with valves shut. pull a plug and shine a bright light in the cylinder via plug hole and look down port.
quitter! lol
lol...I get pissed off for a little bit and had a few choice words with the shop that revamped my heads...that cooled me off a little bit.
I already found another front head and I will be picking it up Monday. Also, already ordered new VSS and a new HG for it as well. I will try and post up pictures of the progress as well.
thats the spirit old boy!
onwards and upwards!?!
I hope its the piston and not the head lol jk
Mods: Evo3 16G turbo's, Titan manifolds, 680cc Denso's, ARC2 w/ large MAS, FMIC, TiAL BOV, DR Stage III heads, AC Delete, Flex-A-Lite fans, 25 row oil cooler,
