Results 1 to 6 of 6
Thread: '95 VR4 Rear hub assembly
    Where the heck do I get one?
    I ordered one from RockAuto, but it was the rear hub assembly for a FWD model, not an AWD model.
    I replaced the other side's hub a few years ago, but for the life of me can't remember where I bought it.
    Anyone know where I can order a rear hub assembly for a '95 vr4?
    (I checked Rockauto and Cherry Hill..couldn't find 'em)
    Aaron, you don't really need the whole rear hub, you can just replace the bearings. If you want a whole assembly, I have them on our 3swarehouse.com site
    cool, thanks, hans I have to pull the stub axle out to inspect it..I had to replace the last one because it was ground down to almost nothing.
    The grinding sounds the same this time, so I figure I'll need the whole assembly..maybe not the flange, but definitely the bearings and probably the stub axle.
    I'll pull it apart this week and find out for sure.
    "this weekend"..what was I thinking?
    4 weekends later...I just pulled it apart and it looks like the shaft is fine. The outer bearing isn't budging. So, I'll only need to order the bearings. (Last time I did this, the outer bearing fell off the shaft when I removed it). Now I have to find a shop to press the new bearing onto the axle..
    Unfortunately, while trying to remove the ABS sensor, the 12mm bolt broke..*grumble*
    You didn't need to remove the sensor
    yeah, i realized that after i had the shaft removed hehe.
