Results 1 to 10 of 12
Thread: Turbo in a Trashcan 1g Talon - 1st shakedown passes!
    The Carolina 3S group met up at Darlington Dragway last weekend for a little get together so I brought my Talon out for it's first shakedown passes. I bought this car a few months back as sort of a fixer-upper project car. It needed a lot of TLC to get back into shape, but it's starting to come together. It still has the weak-ass 3-bolt rear end/axles so I have never tried to launch this car for fear of grenading the rear. My initial plan was to just see what it would MPH; no intention for a good ET.
    Pertinent mods are:
    DSMLink v3 -- very conservative pump gas tune: 10:9 - 11:1 at WOT with only 8-12 degrees of timing
    Rebuild bottom end w/ 1G rods and 2G pistons; balance shafts eliminated
    Mild ported head
    FP2 cams (very mild - still stock springs/retainers)
    old ass bolt-on TD05 internally gated PTE SC61 turbo
    SBR FMIC
    ACT 2600 (done!)
    PTE 1000cc injectors
    Aeromotive A340
    Bad trans - grinds into 3rd
    Cliff notes:
    1st Pass -- Walked it out of the hole and rolled into WOT - nice and easy pass: 12.90 @ 118.8MPH w/ 2.4 60'
    2nd Pass -- Easy slip from 4k RPM - bad ignition break up once I hit 3rd gear; almost aborted the run but it cleared up at the top of 3rd: 12.37 @ 120.7MPH w/ 2.1 60'
    Now I've got the itch to run an 11...!
    3rd Pass -- Turned the 2 step up to 5000RPM but no anti-lag - quick slip with a slight bog - broke up bad at the top of 2nd and into 3rd gear: 11.95 @ 122.1MPH w/ 1.99 60; 7.8 @ 97.9MPH in the 1/8!
    So now I'm getting brave! After some friendly 'encouragement' I decide to go for broke - I did trailer the damn thing there after all! I turned up the 2-step to 5500 and dialed in the anti-lag and lined back up.....
    3th Pass -- Sat on the anti-lag for a second and then gave it a very quick slip - almost a full dump - RPM's shoot to the limiter and sit there - my first inclination is SHIT! tire spin! LOL Not so much... My clutch said OMGWTFBBQ!! I bang into 2nd with a mild bog, hit 3rd and the car brakes up a little, hit 4th and the RPM's just hover as the clutch lets go again: 11.96 @ 120.7MPH w/ 1.91 60'
    Overall I'm more than pleased considering the car still needs a lot of work and is on a super safe, double-bagged tune. Despite my desire to put some timing in and lean it out, I left the tune alone all day and only touched the 2-step/anti-lag settings. Go figure, but I have driven the snot out of this car on the street and have never had any ignition issues until the track. I was running a little fatter than usual, though; usually tune for 11.2 - 11.3 so that may have been a factor. I dropped in the A340 in preparation for E85 (assuming I didn't blow it up at the track) just a few days before and didn't tweak the tune much.
    Next up:
    Clutch!
    4-bolt rear
    Fix boost leak
    Rebuild trans
    re-shim wastegate for more boost
    1750cc injectors and E85!
    Turn it UP!
    Video:
    Formerly:
    Dallas TX
    Brings back memories of my old Talon TSi. So freakin simple to get into the 11's and 12's with those things. Best bang for the buck car ever built IMO.
    The bang for the buck part is mostly true, especially if you buy one already modded that just needs TLC. If you buy one of these cars stockish and then have to mod it in addition to fixing all of the inherent Mitsu fuckups then it's not so cheap. The biggest advantage is weight, or lack thereof, IMO. No PS, AC, CC, and gutted behind the front seats so the car is well under 3000lbs. Even with a lazy turbo the car is so easily to launch, and launch without much 'abuse', since there's not a lot of weight to motivate. If the clutch would have held the car would have easily gone 11.6 that day - I would have put money on it!
    Can't wait to convert E85 and turn it UP!
    Congrats on the nice run man
    Who's green 3000 is that in the beginning of the video?
    Thanks! There are two 3/s in those pics (courtesy of Vicki!). The matte black Stealth w/ matching trailer is Greg's (DrGonzo) and the green VR-4 is Scott's (don't know his forum name).
    I AM IMPORT POWER
    Driving Vicki Crazy
    Yes, that is Scott Simons VR4. Very nice guy, BONE stock VR4. Convinced him to run when he only came to spectate. Then I removed his free boost mod restrictor pill to up his boost and he ran even better. And now he is hooked
    -Chris
    It's scary how good these cars are for cheap horsepower. Can't wait to get mine running. My mods are about the same as yours except with a stock head and a fleabay 16G that came with the car. I think I'm mainly going to autocross mine though.
    Driving Chris back.
    Quote Originally Posted by HellBringer View Post
    hahahaha...i see what you did thar!!!
    One fix at a time verified
    Kansas
    -Chris
    Poor guy. You just stole his wallet. Now that he has the mod bug he won't stop spending.
    DSMs are cheap to mod and can go very quick too but like the 3S's they have quite a few worn parts to replace. I don't think the 3S is quite as bad but is sure isn't too far behind. They're not getting any younger.
    Amazing collection of cars. Your watch looks nicer than I remember from your VR4 days
    What's your goal for this car? Do you plan to keep it? If not, what would you sell it for?
