Maybe we can work out something for our BBK's![]()
Unsure if stock dust shields will work, lol
ha ha, I don't have my front ones anymore anyway. Still got the rears though.
I'd say you can just cut the lip off the fronts and possibly still use them.
It would be cool, but honestly I really don't think it's needed for the rears unless you are on a really small circuit. The fronts can certainly use some. Although, I've removed mine the last few years from the fronts. A good multi spoke wheel however is worth it's weight in gold.
www.stickyvinylgraphics.com
Custom Stickers & Graphics
www.chumpcar.com
IDK Erron, I'm pretty bad on breaksnot as bad as I use to be though.
BTW you care to share your front setup?
Sure! It's nothing fancy. 13.5" rotors, aluminum hats, 1.5" width rotors, AP 6 pots, RBF660 fluid, Raybestos ST47 pads, right foot 3cm smaller than the left.
Oh ya, if you're laughing, you read it correctly! LOL
The ducts were the standard type of setup. Hose, carbon ducts, but I had made a piece that fed the cool air directly into the veins of the rotor between the rotor and the caliper. It was shaped like an eyebrow, thin metal, that bolted to the stock bolt hole location.
I don't. I removed them a while back.
