Results 1 to 5 of 5
Thread: Need to re-wire 92 plug to work with 95 radiator fans. Possible?
    Riding topless!! verified
    Owned 8 3s since 2005.
    Corpus Christi
    The 92 plug from my vr4 has 6 pins and the NA 95 has a 4 pin plug.
    Medford OR
    That pic looks like a driver side fan..? You need to re-wire the passenger side fan correct?
    Corpus Christi
    Actually both fans. The main connection from the fuse box does not match up on the 1st and 2nd gens.
    The first gen had a temp sensor built into the radiator, maybe that's why it has 6 pins and the 2nd gen only had 4.
    Medford OR
    Yes, the first gen has the fans controlled by thermal switches, the 2nd gen is controlled by the ECU...
    What radiator are you using? what harnesses and ECU do you have?
    Corpus Christi
    92 vr4 with 95 Cali spec auto ecu and engine harness. The fuse box wiring is still the stock 92. The radiator and fans are from the 95.
