Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: javascript help
  1. #41
    3SWiki.org
    10+ Years
    The Silver State
    No prob!
  2. #42
    Madison Heights, Mi
    CRAP CRAP CRAP.
    After all that work google does not see the rendered results of all that JS. I'll need to go back to a server side version to get search engines to see it.
    Guess I get to make my 1st VBB plugin
  3. #43
    Never finishes any verified
    Wake Forest, NC
    Wonder why Google is not seeing it.....The bot should just be parsing the rendered source code on the page. Regardless of the contents being hidden by CSS the code is all still there.
    The JS version is perfect as it can be added to any site and still function. VBB plugin will only work with VBB so all other sites will need to have a one off solution......
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  4. #44
    Madison Heights, Mi
    looking at the google webmaster tools google is not parsing the JS at all. It does not even load it. This is based on a review of 3sg.org so its not a crossdomain issue.
    I went with JS because of the issues you point out. I can setup test SMF and phpBB boards so I can make a plugin for them too.
  5. #45
    Wake Forest, NC
    Yeah I just pulled the page into Lynx and it's not actually writing like I thought..... But Google does parse links embedded in Javascript and Ajax, so wonder if it's just a WM Tools issue than?!?!?
  6. #46
    Madison Heights, Mi
    If it was just a WM thing I should be seeing inbound links to 3sg.org
  7. #47
    3SWiki.org
    10+ Years
    The Silver State
    Well that's a pain. We should write Google a strongly-worded letter.
  8. #48
    Madison Heights, Mi
    I have a PHP version working http://www.3sg.org/footer/footer.php
    I have a vbb 4 plugin for it. I just need someone brave enough to test it
  9. #49
    Wake Forest, NC
    Installed and working correctly on VBB You can see it running on http://colorado3s.org
    I checked the source code and all of the links are writing out correctly now. So GA should start picking them up. Took less than 5 min to install the plugin.
    Good Job Alan!!!
  10. #50
    Madison Heights, Mi
    Now to make one for vb 3, SMF and the phpBB variants
