Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
Thread: javascript help
  1. #31
    3SWiki.org
    10+ Years
    The Silver State
    By the way, one thing I've been meaning to mention:
    For some of your links, you don't list the fully qualified (absolute) URL. So, for example, 3sg.org links to "http://mi3si.org/beta/www.3sg.org" instead. It happens on the Texas 3S, 3SI, 3SGTO, 3SG and Blue Ridge Gathering links. Just thought I'd give you a heads up in case you hadn't noticed yet.
  2. #32
    Madison Heights, Mi
    The array is temporary until I have time to make the database to store them. That code will ensure that all url's have http on them before they are put in the array.
    Thanks a ton.
    NOw I just need to get the code to load jquery in plain JS working so the HTML just needs one script tag
  3. #33
    Madison Heights, Mi
    I've tried several variation on this to get jquery to load within an js file.
    PHP Code:
        function getScript(url,success){
           var
    head= document.getElementsByTagName('head')[0];
           var
    script= document.createElement('script');
    script.type= 'text/javascript';
    script.src= url;
    script.async = true;
    document.body.appendChild(script);
        var
    jqueryUrl = "http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js";
    getScript(jqueryUrl);
    The JS is loaded into the document but it does not initialize.
  4. #34
    Madison Heights, Mi
    Before you ask, I am trying to get this all done in one call.
    PHP Code:
      <script src="http://www.3sg.org/beta/3sg_footer.js"></script>
  5. #35
    3SWiki.org
    10+ Years
    The Silver State
    Quote Originally Posted by Alan92RTTT View Post
    PHP Code:
    Done.
    3SG.org Tabs Demo (Source)
    3SG.org Tabs Demo (Remote Server)
  6. #36
    Madison Heights, Mi
    Can you explain a few things?
    Everything I have read says you should not use document.write yet you did and it works fine.
    Whats with the "scr"+"pt" in the document writes?
  7. #37
    3SWiki.org
    10+ Years
    The Silver State
    Old habits die hard - the scr + pt is legacy code for older browsers. It was taught to me when I was first getting started, but it can be changed to your way and should work the same. Here's some more details:
    document.write('<SCR' + 'IPT>'), why? JavaScript and AJAX forum at WebmasterWorld
    I've updated my .js file to use the createElement + appendChild methods instead, if that's what you'd prefer to go with.
  8. #38
    Madison Heights, Mi
    Well i have a working page. I'm not sure why some things are working as its written and not the way they were but it looks to be working.
    NOt sure why the document.ready code had to be put in a function and call the way it is.
  9. #39
    3SWiki.org
    10+ Years
    The Silver State
    I'm not a fan of scripting languages But with the help of jQuery, etc, it has come a long way.
    Glad to see it all working!
  10. #40
    Madison Heights, Mi
    Workign from 3sg.org - 3000GT / Stealth / GTO information and Michigan 3SI yay!
    Thanks alot.
