Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: javascript help
    Madison Heights, Mi
    you still have AIM?
    FYI, you pulled some of the stuff I did with color. I did that so it would pick up the color for what ever page it on. I did not want the tab/links hard coded for color.
    Madison Heights, Mi
    I think I see the problem. The appendTo's are not done rendering when the last block of JS is run and its errors. I need a way to make it wait for them.
    Madison Heights, Mi
    I think I have it.
    Now the next step. I need to be able to include it in an html page with a script tag. fun...
  4. #24
    3SWiki.org
    10+ Years
    The Silver State
    I do still have AIM, Shaun I Am.
    I'll keep troubleshooting with you. I think you're in the home stretch now though.
  5. #25
    Madison Heights, Mi
    I'm having an issue with the json call.
    I've moved the html to http://mi3si.org/beta/3sg_footer-2.htm because I am trying to test loading the json from a separate server using jsonp.
    You can see the json here http://3sg.org/beta/include_js.php
    The JS is coming from 3sg.org and running with no issue until it throws a "missing variable name" error when processing the json results.
    json call code.
    PHP Code:
        var data = $.ajax({
    url : 'http://www.3sg.org/beta/include_js.php',
    dataType : "jsonp",
    jsonp: 'callback',
    jsonpCallback: 'getData',
    timeout : 10000,
    success: function(){
    alert("success");
        function
    getData(data){
    '#tabHeader').text(data.message);
  6. #26
    3SWiki.org
    10+ Years
    The Silver State
    Hmm, if you want to use jsonp, here's how I did it:
    3SG.org Tabs Demo (Remote Server)
    My copy of the json file that the Portland3S domain is accessing can be found at:
    http://www.stealthify.com/3sgto/proj...absXserver.php
    Does it work for you?
  7. #27
    Madison Heights, Mi
    oh this is frustrating. My code with your include works. With mine(which seems to return the same thing) does not work.
    ARG.
    PHP Code:
    <?php
        $data
    = array(
    "groups"=> array(
                 array(
    "name" => "Events",
    "title" => "3000GT/Stealth/GTO Event Pages",
    "links" => array(
                        array(
    "name"=>"3S National Gathering","url"=>"http://www.3sng.org"),
                        array(
    "name"=>"East Coast Gathering","url"=>"http://www.3secg.com"),
                        array(
    "name"=>"Upper Mid-West Gathering","url"=>"http://umg.mn3s.org"),
                        array(
    "name"=>"Blue Ridge Gathering","url"=>"www.blueridgegathering.com"),
                 array(
    "name" => "Groups",
    "title" => "3000GT/Stealth/GTO Clubs and Groups",
    "links" => array(
                        array(
    "name"=>"Michigan 3S","url"=>"http://www.mi3si.org"),
                        array(
    "name"=>"MInnesota 3S","url"=>"http://www.mn3s.org"),
                        array(
    "name"=>"Wisconsin 3S","url"=>"http://www.w3si.org"),
                        array(
    "name"=>"3000GT/Stealth/GTO Forums","url"=>"www.3sgto.org"),
                        array(
    "name"=>"Texas 3S","url"=>"www.texas3s.com"),
                        array(
    "name"=>"3000GT/Stealth International","url"=>"www.3sl.org"),
                 array(
    "name" => "Information",
    "title" => "3000GT/Stealth/GTO Information and Resources",
    "links" => array(
                        array(
    "name"=>"Stealth 316","url"=>"http://www.3sng.org"),
                        array(
    "name"=>"3000GT / Stealth / GTO Information","url"=>"www.3sg.org"),
    $json_data = json_encode($data);
        echo
    '<pre>('. $json_data.');</pre>';
  8. #28
    3SWiki.org
    10+ Years
    The Silver State
    Remove the pre tags, and designate a callback function (or use the automatically generated one):
    PHP Code:
    <?php
    // Build Links Array
    $data = array(
    "groups"=> array(
                 array(
    "name" => "Events",
    "links" => array(
                        array(
                        array(
                        array(
                        array(
    "name"=>"Blue Ridge Gathering","url"=>"http://www.blueridgegathering.com"),
                 array(
    "name" => "Groups",
    "links" => array(
                        array(
                        array(
                        array(
                        array(
    "name"=>"3000GT/Stealth/GTO Forums","url"=>"http://www.3sgto.org"),
                        array(
    "name"=>"Texas 3S","url"=>"http://www.texas3s.com"),
                        array(
    "name"=>"3000GT/Stealth International","url"=>"http://www.3si.org"),
                 array(
    "links" => array(
                        array(
                        array(
    "name"=>"3000GT / Stealth / GTO Information","url"=>"http://www.3sg.org"),
    // Encode Links Array to JSON
    // Collect & Sanitize Random callback parameter
    $callback = preg_replace("/[^a-zA-Z0-9\.\_\[\]]+/", "", $_GET['callback']);
    // Output Results
    echo $callback.'('.$json_data.');';
  9. #29
    Madison Heights, Mi
    ah you have some extra stuff in your include
    I had a feeling that was the case. I added the pre's because they came out if I pulled your file up in a browser
    AWESOME
  10. #30
    3SWiki.org
    10+ Years
    The Silver State
    Nice! Glad it worked.
    Enjoy.
