Results 11 to 20 of 50
Thread: javascript help
    3SWiki.org
    10+ Years
    The Silver State
    Should do the trick, and hope that helps. Let me know how it goes.
    Madison Heights, Mi
    thanks. I will
    Madison Heights, Mi
    I got it working, I changed it a bit and it still worked.
    I added the code to add the links and %_*)*)*(%^#
    PHP Code:
    <head>
    style>
    div.div_3sg
    width: 100%;
    div.tab_3sg
    border: 1px solid;
    margin: auto;
    clear: both;
    height: 120px;
    width: 98%;
    padding-left: 4px;
    #tabs li {
    list-style: none outside none;
    #tabs ul {
    padding: 0;
    border-bottom: 0 none !important;
    #tabs li, #tabs li a {
    float: left;
    #tabs ul li{
    font-weight: bold;
    padding: 8px;
    text-decoration: none;
    cursor: pointer;
    style>
    script src="http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
    </head>
    <body>
    <div id="tabs" class="div_3sg">
        <div  id="tabHeader"  style="display: block; float: left; ">
           <ul  id="tabUl" >
                <!-- Tabs Generated Here -->
           </ul>
        </div>
    </div>
    <div id="hidden" style="display:none" class="user_css"><label id="text_color">text</label><a id="link_color" href="#">text</a></div>
    </body>
    <script>
        $(document).ready(function(){
            $.getJSON( "include_js.php",function(data){
                var items = [];
                $.each(data.groups, function(id, group) {
                    $('<li id="#tab-'+(id+1)+'">'+group.name+'</li>').appendTo('#tabUl');
                    var div = '<div id="tab-'+(id+1)+'" class="tab_3sg">';
                    div = div +'<b>'+group.title+'</b><br>';
                    $.each(group.links, function(id, link) {
                        div = div + '<a href="'+link.url+'">'+link.name+'</a><br>';
                    div = div + '</div>';
                    $(div).appendTo('#tabs');
            $('#tabs .tab_3sg').hide();
            $('#tabs .tab_3sg:first').show();
            $('#tabs ul li:first').addClass('active');
            var text_color = $('#text_color').css("color");
            var link_color = $('#link_color').css("color");
            $('#tabs ul li').css('color',link_color);
            $('#tabs ul li:first').css('color', text_color);
            $('#tabs ul li').click(function(){
                $('#tabs ul li').removeClass('active');
                $(this).addClass('active');
                var currentTab = $(this).attr('id');
                $(currentTab).show();
                $('#tabs ul li').css('color', $('#link_color').css("color"));
                $(this).css('color', $('#text_color').css("color"));
                return false;
    </script>
    You can see what its doing on http://3sg.org/beta/3sg_footer.htm
    Stuper Moderator
    January 2003
    Quote Originally Posted by Alan92RTTT View Post
    The bottom cell, the 1st clickable link is underneath of the header text for that cell. Can not click on it. I'm viewing with Chrome.
    Douches
    Madison Heights, Mi
    if the javascript was working that would not be an issue
    That page should look/work like the block at the bottom of the page here when its done.
    3SWiki.org
    10+ Years
    The Silver State
    So close. Now the problem is the div.tab_3sg CSS parameter. You have it set to a static height of 120px, when perhaps it might be better suited to use a min-height:120px instead.
    Madison Heights, Mi
    Height is not the issue unless the JS is working in your browser.
    this part of the JS is not running in FF
    PHP Code:
            var
            var
                var
    currentTab).show();
                return
    false;
  8. #18
    3SWiki.org
    10+ Years
    The Silver State
    Height is an issue when you are programmatically trying to cram more vertical content into a div than you have made room for via CSS.
    I know this because the text overlap under your third header is from the runoff of the div above it.
    I have updated my version to demonstrate/help:
    http://stealthify.com/3sgto/projects/3sgTabs.php
  9. #19
    3SWiki.org
    10+ Years
    The Silver State
    But I see what you're saying. Your JavaScript wasn't working in my browser, but even so you would still have a runoff outside of the container div.
    The version I just posted should solve that. Hope that helps.
  10. #20
    Madison Heights, Mi
    Runoff issue fixed in my version.
