Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: javascript help
    Madison Heights, Mi
    javascript help
    I'm having an issue with this code
    PHP Code:
    <head>
    style>
    div.div_3sg
    width: 100%;
    div.tab_3sg
    border: 1px solid;
    margin: auto;
    clear: both;
    height: 120px;
    width: 98%;
    padding-left: 4px;
    #tabs li {
    list-style: none outside none;
    #tabs ul {
    padding: 0;
    border-bottom: 0 none !important;
    #tabs li, #tabs li a {
    float: left;
    #tabs ul li{
    font-weight: bold;
    padding: 8px;
    text-decoration: none;
    cursor: pointer;
    style>
    head>
    script type="text/javascript">
    document.write("\<script src='//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js' type='text/javascript'>\<\/script>");
    </script>
    <body>
    <div id="tabs" class="div_3sg">
        <div style="display: block; float: left; ">
           <ul>
    <script type="text/javascript">
        jQuery.getJSON( "include_js.php",function(data){
            jQuery.each(data.groups, function(id, group){
                var a=1;
                document.writeln('<li id="#tab-'+(id+1)+'">A'+group.name+'</li>');
    </script>
           </ul>
        </div>
    </div>
    </body>
    That code produces the following result.
    PHP Code:
    <li id="#tab-1">AEvents</li>
    li id="#tab-2">AGroups</li>
    li id="#tab-3">AInformation</li>
    Can anyone see why its freaking out and clearing everything off the page.
    |RLII Photography| Not Verified
    Rocket City, AL
    Looks like you missed a </div> tag on the tag before the </body> tag.
    1994 Mariana Blue Pearl Mitsubishi 3000GT VR-4
    DR-650s and supporting, PST CFDS, Volk GT-Cs, Tein Flex, among other things
    Feb. 06 3SI ROTM - Best AWD BRG 07 - 3rd Place 2G 07 3/S National Gathering - People's Choice BRG 08
    BRG 2011 Total Package - NG11 Car Show 1st Place
    2010 Space Gray E90 335i M-Sport 6MT - 400whp/450wtq
    2002 Jet Black E53 X5 4.4i AWD - Bavarian Workhorse
    Madison Heights, Mi
    Fixed the div tag, no change.
    If it helps in FF the spinner on the tab keeps spinning.
    I've got to get some nocache headers in it. It runs once, fails and I can't open fire bug on it and get it to rereun without closing the tab and entering it from the address bar(no shift-refresh does not work)
    Madison Heights, Mi
    uploaded here if anyone wants to look
    http://3sg.org/beta/3sg_footer.htm
    3SWiki.org
    10+ Years
    The Silver State
    Give this a try:
    PHP Code:
    <head>
    style>
    div.div_3sg
    width: 100%;
    div.tab_3sg
    border: 1px solid;
    margin: auto;
    clear: both;
    height: 120px;
    width: 98%;
    padding-left: 4px;
    #tabs li {
    #tabs ul {
    padding: 0;
    float: left;
    #tabs ul li{
    font-weight: bold;
    padding: 8px;
    cursor: pointer;
    style>
    script src="http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
    </head>
    <body>
        <div id="tabHeader" style="display:block; float:left;">
            <!-- Tabs Generated Here -->
        </div>
    </div>
    <script>
    $.getJSON('3sgTabs.json', function(data) {
        var items = [];
        $.each(data.groups, function(id, group) {
            items.push('<li id="tab-' + (id+1) + '">' + group.name + '</li>');
        $('<ul/>', {
            'class': 'tabCategories',
            html: items.join('')
        }).appendTo('#tabHeader');
    </script>
    </body>
    Output generated is:
    PHP Code:
    ul class="tabCategories">
    li id="tab-1">Events</li>
    li id="tab-2">Groups</li>
    li id="tab-3">Information</li>
    ul>
    div>
    div>
    Working demo:
    http://www.stealthify.com/3sgto/projects/3sgTabs.php
    Madison Heights, Mi
    Can you explain why what I did , did what it did?
    3SWiki.org
    10+ Years
    The Silver State
    I didn't look too far into it. I just recreated it from scratch with how I would do it, and then adapted it to what you were trying to accomplish.
    Looking at it a little closer now, your problem line is using document.writeln to begin writing to the document and then not using the document.close() method to close the output stream.
    Madison Heights, Mi
    I originally used document.write() would that still need the close?
    3SWiki.org
    10+ Years
    The Silver State
    Yep, that's pretty much identical to .writeln, except .writeln will put a new line after it. Both open and write to the output stream.
    Once all the writes are performed, the document.close() method causes any output written to the output stream to be displayed.
    Madison Heights, Mi
    wonder if thats what broke it.
    I'll have to try it at lunch
    I'll probably use yours tho I like it better.
