strut bars. not this.
not sure how it would benefit though. it bolts into a section of the car that isn't really weakened by cutting the top off. if anything, i'd say you need stiffness front-to-back along the door sills, along the a-pillar, and up top by the b-pillars. laterally behind the seats seems (in my mind) to not pose much benefit.
spyder already has all those reinforcements .... + spyder also has a huge rear bracing between the rear shock towers. and plates are welded inside the front and rear fenders, and a massive bulkhead, an inverted U in cross section, gets welded in between the rear inner fenders. This piece ties into the rockerpannel reinforcements, yet still the mid section of the spyder in certain situations, feels like a wet noodle. not very noticeable with the stock shocks/springs but once you install coilovers / stiffer springs the mid section chassis flex really becomes very noticeable. one can also note the chassis flex if you park the spyder on enough uneven ground and try to close the top the top wont close because it won't align correctly with the windshield... I think a cross floor bar would possibly help a great deal to reduce the mid section chassis flex on a spyder as it bolts down to the rockerpannel reinforcements and ties them together some more. -basically acts like a one extra ladder would act on a ladder frame
eh, maybe. still seems like the most "twisting" would be done directly along the door sills though.
Frame: l l
Frame with brace: H
The heavy duty one in the pick above looks like it would help a lot in a spyder
