Results 1 to 10 of 28
Thread: Bad Thump in Drivetrain "Not The Driveshaft"
    Never finishes any verified
    Wake Forest, NC
    Angry Bad Thump in Drivetrain "Not The Driveshaft"
    For the longest time now I have had a really bad thump in the drivetrain that usually occurs when I'm in a gear and give it gas. The issue is too much slack in the drivetrain and when I give it gas it will thump bad until the slack is taken up.
    I initially though it was the driveshaft for two reasons, Every thread about drivetrain thump gets directed to Bad Carrier bearings and I had a lot of slack in my driveshaft.
    I swapped out the driveshaft with another and still the same issue, I swapped out the read diff and still the SAME ISSUE!!!!
    So I checked the Driveshaft again and even the used replacement had a lot of up/down - side/side play. Well I was not going to drop almost $200.00 on new carrier bearings as I was still not convinced it was the carrier bearings caused the thumping. So I took my spare driveshaft and willed in the carrier bearing doughnut with polyurethane. Let it setup for about a week and re-installed it. There is ZERO play in the driveshaft now but I can twist it almost two inches either direct.
    Why is there so much slack in the driveshaft? This slack is what is giving me the damn thumping and I don't know how to alleviate it. Any Ideas??
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    VR-3747 :D Not Verified
    Dayton Ohio
    Check your motor mounts
    Wake Forest, NC
    There Solids......
    you know you like it Not Verified
    Sacramento CA
    Output shaft stripped
    Wake Forest, NC
    Here's pics of the output shaft I took in Nov 2011. Car had pretty much been sitting since then as I didn't drive it much in the winter.
    T-case slop or tranny internals then.
    Secret Lurker Man! verified
    7/10/06 or somethin
    Bend, Oregon
    You try adjusting rear diff backlash? That's on my to do list...there's an informative thread on the other site...
    Wake Forest, NC
    Quote Originally Posted by Nihil View Post
    Got the URL for that thread? All the ones I have read don't have any decent details on it. Manual is pretty shady about the procedure also.
    7/10/06 or somethin
    Bend, Oregon
    I hate linkin to the other site ha but yeahhhh....here ya gooooo Adjusted Rear Diff Backlash, some hints - 3000GT/Stealth International Message Center
    JNS Engineering verified
    San Jose, CA
    It's pretty easy to measure the backlash and see if you have a problem. I had a leak at the pinion seal and ended up measuring BL just to make sure everything was OK. I just needed a new seal as the old one was worn out.
