Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: GZP Performance Cam Gears!!!!
    OG Member verified
    Sep 2011
    Elkhart, TX
    Glad to see these on the market, I would be curious to try a set sometime as well with back to back results.
    I will get a set but in for results first as well
    Hans, let me know when you will be looking for more cam gears. I might still have a set or two sitting around.
    I'll put up a post once I need some
    Player Hater of the Year
    San Antonio, TX
    I got a set of Jackhammer's gears, the same product only powder coated black, but these are awesome.
    Like they said, no more messing around with aftermarket adjustable gears and they stay put!
    I could definitely feel the difference on a nearly stock car.
    I'm Kind Of A Big Deal
    Dyno testing is COMPLETED!!
    Dyno Tested, back to back. NO OTHER MODIFICATIONS WERE MADE TO THIS CAR.
    RunFile_002.drf (GREEN LINES) Stock Cam Gears on a bone stock 91 3000GT VR-4
    RunFile_007.drf (RED LINES) GZP Performance Cam Gears on a bone stock 91 3000GT VR-4
    These numbers are SAE corrected, with boost pressure reading listed below dyno chart.
    Order yours today!!!
    Once the first batch is gone, our discounted pricing goes with it!
    http://www.3swarehouse.com/index.php...emart&Itemid=1
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
  7. #17
    How would these compare to bolting them onto 272/264 cams on an NA
  8. #18
    We could not speculate. Only way to know for sure is to get some back to back numbers.
  9. #19
    One fix at a time verified
    Kansas
    Wow, look at the area under the curve for a stock car! It's crazy how this has the opposite effect of cams and helps the low end that much. I'm sure the timing settings intensify the fact that 9bs run out of steam at higher rpms.
  10. #20
    Plotted the peak gains
