Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: GZP Performance Cam Gears!!!!
  1. #41
    Medford OR
    +1 im really curious if niterydr was right and the cam gears are just modifying the base ignition timing. however, since the CAS sensor takes readings from the intake cam only (right?), im guessing the GZP cam gears dont just shift the ignition timing... otherwise there would be no point to the exhaust cam gear.
    Installing these gears with no other change will advance the ign. timing 2 deg. on a 1st gen, and make no change at all on a 2nd gen.
    Edit: Make that 91-92, and 93+... Just so I don't get dogpiled by generational correctness.
  2. #42
    Hmmmm maybe I will do a before and after when my build is done. Depends how much work it would take tho.
  3. #43
    Wait, so no change on 2nd gen cars? I am confused...
  4. #44
    Medford OR
    Crank and cam sensors are not affected by camshaft timing... Only the CAS on a 91-92 that is driven off the intake cam is affected by changes in cam timing.
    Edit: you guys do realize I was responding only on the subject of these gears having an effect on ignition timing, right..?
  5. #45
    Delaware
    so cam gears have no effect on 93+ cars?
    Jason
  6. #46
    Medford OR
    Jason
    No effect on ignition timing... That's all I said.
  8. #48
    Delaware
    gotcha...
    Jason
  9. #49
    10/4!
    After explaining the ignition timing I was in the duh zone... Thank you...
    Paul be nice! lol
  10. #50
    Sorry, I didn't think he understood what these did.
