Results 31 to 40 of 57
Thread: GZP Performance Cam Gears!!!!
  1. #31
    Cool stuff! Not that many will care but does this have a negative impact on fuel economy?
    I doubt you will see negative effects for highway mileage.
  2. #32
    We could not speculate. Only way to know for sure is to get some back to back numbers.
    Well I know one way you could find out
  3. #33
    I'm Kind Of A Big Deal
    Quote Originally Posted by 1320VR4 View Post
    I'll PM you the shipping address for those cams
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
  4. #34
    Makes me look forward to installing my jackhammer cam gears. I've got basically stock heads (and stock cams) so I would expect similar across-the-board gains.
  5. #35
    Any updates on this on a somewhat more modded car..?
  6. #36
    OG Member verified
    Sep 2011
    Elkhart, TX
    Thinking out loud here, with the cam gears dropped in, are you re-syncing base timing? I wonder if the "gains across the board" are due to the base timing shift? Thought would be that the cas sensor is spun as the cams are spun to align with the new mark, this changing base timing.
    I wonder what the effect would be on a 2g car?
  7. #37
    When we had done the cam gears we had the ecu crap out which was throwing a CEL for a cas. So, it was replaced only to find that the ecu was bad. I'll be getting our other stealth together within the next couple of weeks to try to get more back to back numbers. These initial numbers were done on a car we have for sale, so I really don't want to go tinkering in that thing anymore... but you do make a valid point.
  8. #38
    Do you guys plan on doing anymore stock vs gzp gear dyno runs?
    I can't wait to get all my stuff assembled.
  9. #39
    Quote Originally Posted by niterydr View Post
    +1 im really curious if niterydr was right and the cam gears are just modifying the base ignition timing. however, since the CAS sensor takes readings from the intake cam only (right?), im guessing the GZP cam gears dont just shift the ignition timing... otherwise there would be no point to the exhaust cam gear.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
  10. #40
    we will do more dyno tests when the time is right. Right now we don't have a car we would run them on.
