Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: GZP Performance Cam Gears!!!!
    I'm Kind Of A Big Deal
    UPDATED: DYNO COMPARISIONS!
    Sets are in stock, and ready to go!! You can click the link below to place your order
    http://www.3swarehouse.com/index.php...emart&Itemid=1
    Here's an easy way to get the power of adjustable cam gears, with the reliability of OEM gears, and take away the guess work. These OEM gears are reconfigured to the +1 and -3 degree positions that are found to be the optimal settings for adjustable camgears. Now, all you have to do is install, and forget about them. No more having to worry about the gear slipping out of time or trying to get them dialed in just right. All of the hard work is done for you.
    The hole for the dowel has also been redrilled, and reduced in size ever so slighlty for a perfect fit and to get rid of the marginal degree of "slop" that you find with the dowel pin hole on the factory original cam gears and some of the other aftermarket adjustable cam gears that are out there.
    This is compatible with all DOHC engine configurations. This is NOT suitable for SOHC applications. Please select the year range that applies to your vehicle. If you have any questions, please ask before placing your order.
    Each set of cam gears comes with an instruction sheet, and a pre-paid return shipping label for your core cam gears. Each set of returned cam gears (qty 4) will receive a $30 refund. If you send back 2 sets, that's $60, 3 sets, $90... so on and so forth.
    Dyno testing is COMPLETED!!
    Dyno Tested, back to back. NO OTHER MODIFICATIONS WERE MADE TO THIS CAR.
    RunFile_002.drf (GREEN LINES) Stock Cam Gears on a bone stock 91 3000GT VR-4
    RunFile_007.drf (RED LINES) GZP Performance Cam Gears on a bone stock 91 3000GT VR-4
    These numbers are SAE corrected, with boost pressure reading listed below dyno chart.
    Thanks!!
    Em & Hans
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    So are you buying cam gears now? Or going to wait to see how sales do?
    We already have 16 sets in stock and ready to go and another 6-10 sets here. We'll be buying some shortly once we're done buying them in bulk.
    Hans - how about the quick low-down on what these will do for us in absolute numbers?
    Fowlerville, MI
    They definitely cause a kick in the pants around 5k on my setup. I did feel that I lost a little bottom end.
    3sx claims 55ft-lbs and 57hp running 19psi with this cam setting on their lightweight adjustable cam gears. Expect a hair less gain do to still being stock weight.
  6. The Following User Says Thank You to B-Man For This Useful Post:
  7. #6
    When we have an opportunity, we will be doing back to back dyno tests. We will see if we can get some on an otherwise relatively stock car, as well as a modified car.
  8. #7
    You should test it on that blue stealth
  9. #8
  10. #9
    Good as it gets, there.
  11. #10
    Nice.
    I am in for numbers. And a set if I like what I see.
    Also, I will have 2 sets to mail back to you.
