Drained the oil and noticed silver flecks in the oil. So I dropped the oil pan and found this in the bottom of the pan.
I then proceeded to remove the rod bearing from #6 and found this
So now what do I do? Of course new bearings, and check the crank. But what should be done about the metal in the oil system? Is the engine toast, or can I salvage it?
Thanks for the help!!!
