Page 1 of 8 123 ... LastLast
Results 1 to 10 of 79
Thread: 94 twin turbo stealth wont start
    I just recently put my engine back together with the heads jrod (from Oklahoma)sold me. Only thing i did different when i put it back together was vac reduction. This was done following the wiki-how section of the forum.
    I have fuel and fire for sure. She comes to life for about 5 seconds at about 300 rpm and just falls flat on her face. I can push the pedal in and everything, completely un-responsive.
    When it falls flat on its face, it cough's out of the exhaust side.
    I cant seem to find my issue... putting the motor back together was one thing but trouble shooting what i have going on is different for me. I have never heard a motor do this before.
    Thx for any help
    Canaan NH
    Recheck your mechanical timing first.
    I was a tooth off on the front cam. The other 3 cams were perfect.
    Canaan NH
    Well the front cam is a exhaust cam, might explaint the coughing out the exhaust. Should still run though. I would suggest a perssure test on the intake, did you make sure the MAF is plugged in ? Also a compression test would be a good idea.
    I have no had much time to really do anything but check what i have done. Everything is plugged in but the front o2 sensor.
    Oklahoma just had there statewide meet so i had to leave my car for 2 days. Ill read up how to do compression testing and do it.
    Canaan NH
    Why is the front O2 not connected, I believe it needs to be hooked up to run, not sure though maybe it would just run bad.
    I dont even have all my exhaust hooked up but i was under the impression turbo cars dont need back preasure. Ill get that sensor hooked back up but i dont think it would keep it from starting.
    Keeping it real...
    Oct. 2006
    Reno, NV
    Plug in the front o2.
    Man vs 3/S verified
    Kingston, WA
    my front 02 reads 0.00 volts at all times (its even new something else is wrong). Having a bad front 02 wont make your car not start.....
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    Thats what i thought. Thats why its not a main concern. Ill keep looking around and see what i can do.
