Page 11 of 11 FirstFirst ... 91011
Results 101 to 110 of 110
Thread: Disassembly: Manifold Pressure Differential Sensor
  1. #101
    I lack color... verified
    Aug 1998
    Got it!
    I'm up in Easton flash tuning a couple cars, diagnosing the NLTS issue on Aaron's car, getting new tires for my car and entertaining a date with a hot chick.
    Get back to you on Monday! Got a much better understanding of what's going on now. Will explain later.
  2. #102
    www.chromedecu.org verified
    DFW
    Did we resolve this issue?
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  3. #103
    Aug 1998
    Quote Originally Posted by Jesters Deadd View Post
    No but I've been working with Marc on it. Made some progress this week. I'm writing something up for him to try right now actually.
    His and my availability just don't match up well so progress is slow.
  4. #104
    Aug 1998
    Oh speaking of, remember that timer I mentioned earlier? I believe It's actually a function based off the change in speed. I'm pretty certain the purge activates if your speed does t change for a long period of time. Like when you're cruising for a long time or just idling in traffic and not moving.
  5. #105
    DFW
    timer huh? that seems like it could be used for other coding tricks.
  6. #106
    Aug 1998
    No, this is specifically for the speedo. ...unfortunately....
    I'm wondering if the reason the solinoid activates on Marc car is because he lets the motor warm up at idle.
  7. #107
    Unlikely since once the car is at operating temp - if you turn it off and then restart the solenoid will start clicking within just a few seconds of startup.
    '95 Spyder VR4:
    Exterior/Suspension: '99Front End/Rear Garnish; 19x9 370Z forged Rays Eng wheels; CF 575 Hood; Tein S tech (front) and H tech (rear) springs with rear adjustable control arms; Adjustable Front Tein Pillow Ball Mounts.
    Interior: Hella TPMS; LCDBC; Remote Top; Interior Rearview Mirror with Temp/Compass/HomeLink.
    Brakes: DBA 4000 Slotted Rotors - HPS Pads - SS brake lines.
    Performance: Pampena Bell-housing reinforcement; Pampena pistons; Ninja Lightweight Rods; Dynamic Racing Stage 3 heads and Billet DR650s w/9 Blade turbine and Billet actuators; ported I/E manifolds; DSM SMICs; ID1000s; Flashable ECU ('98) - Chrome 2.0; GM 85mm MAF & translator; 3SX Downpipe; IPS Quad tip exhaust; Walbro 450LPH E-85 fuel pump; K&N fuel filter; AEM AFPR; ACT pressure plate MB019; Maximal/Setrab Oil Cooler; 3SX high capacity radiator; 3SX adjustable cam gears; 3SX Poly mounts; HKS Twin Power.
  8. #108
    Aug 1998
    Quote Originally Posted by awdonly View Post
    So maybe it's not a speedo delta like I originally thought. It's just when the car isn't moving at all.
  9. #109
    Think I may have just figured out your timer. Fresh DR650s are in and car is idling in garage while I inspect for water/oil leaks and letting the penetrating oil burn off. For complete disclosure, I've also changed to EVO MAF and 560s. The purge valve started clicking as soon as car was warm, but after another few minutes it stopped - after about a minute its back on....
  10. #110
    Hopewell Junction, NY
    does anyone have a diagram on which pin is what on the map?
    for the people adding them
    Kx
