Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 110
Thread: Disassembly: Manifold Pressure Differential Sensor
  1. #91
    New software installed - Activation 100 - deactivation 62; The f**king thing still starts ticking after about 5 min of warmup
    '95 Spyder VR4:
    Exterior/Suspension: '99Front End/Rear Garnish; 19x9 370Z forged Rays Eng wheels; CF 575 Hood; Tein S tech (front) and H tech (rear) springs with rear adjustable control arms; Adjustable Front Tein Pillow Ball Mounts.
    Interior: Hella TPMS; LCDBC; Remote Top; Interior Rearview Mirror with Temp/Compass/HomeLink.
    Brakes: DBA 4000 Slotted Rotors - HPS Pads - SS brake lines.
    Performance: Pampena Bell-housing reinforcement; Pampena pistons; Ninja Lightweight Rods; Dynamic Racing Stage 3 heads and Billet DR650s w/9 Blade turbine and Billet actuators; ported I/E manifolds; DSM SMICs; ID1000s; Flashable ECU ('98) - Chrome 2.0; GM 85mm MAF & translator; 3SX Downpipe; IPS Quad tip exhaust; Walbro 450LPH E-85 fuel pump; K&N fuel filter; AEM AFPR; ACT pressure plate MB019; Maximal/Setrab Oil Cooler; 3SX high capacity radiator; 3SX adjustable cam gears; 3SX Poly mounts; HKS Twin Power.
  2. #92
    For the sake of completeness - pin 52 stays low when clicking; Idle switch shows 0 in datalog and airflow is 56Hz.
  3. #93
    I lack color... verified
    Aug 1998
    Had a feeling you'd say that... There's also a timer function which activates the solenoid. I didn't run my car long enough to see if it turned back on.
    I'll pick this up again tonight.
    BTW, have you driven you car yet?
  4. #94
    Not since this most recent update, but I did the day before yesterday when it was hot. I'll be away from the car for the next 10 days. Sorry.
  5. #95
    www.chromedecu.org verified
    DFW
    Can you explain more about this timer function?
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  6. #96
    Aug 1998
    I will when I understand it better
  7. #97
    I'm back. Any progress?
  8. #98
    Aug 1998
    Quote Originally Posted by awdonly View Post
    Yes. Quite a bit actually. I'll post up later this weekend.
  9. #99
    Aug 1998
    Btw what's your email and/or cell? Probably better to talk that way instead of thru here.
  10. #100
    PM sent
