Results 1 to 10 of 27
Thread: Resurfaced heads..... machined or belt sanded?
    Turbo Timebomb
    Elkhart, IN
    Okay, not a machinist here, something seems a bit screwy. I had my heads resurfaced a long time ago by Napa. I got them back and the surface was nice and shiny, perfectly smoothe. I had another set of heads done recently by a performance shop Pro-Motor which a lot of people seem to like the place. When I dropped them off, he asked if they had been previously belt sanded. I didn't really think about it until I got the heads back and you could see the tooling lines. He used what appeared to be a CNC mill w/ a large-diameter round disk with the tooling mounted near the outside of it. Were the heads belt sanded smoothe before? I would assume this is not a good idea. One of my concerns is the machining lines can be felt w/ my thumbnail, is this going to be a problem? I did a little google image search and found both situations, anyone have any inseight on this?
    the reason the heads are off is a graphite head gasket failure, bought multilayered steel this time.
    owner since 2004
    cheshire, england
    once the heads are milled they should be smooth you shouldn't feel anything.
    sounds like a poor job to me. dunno what they mean about belt sanding? never heard of this on heads before.
    Dallas TX
    Some shops don't have the proper tooling to mill a cylinder head. But if they have a decent sized belt sander, you can usually fit a V6 cylinder head on there. It isn't the most professional way of doing things, but unless your heads were severely warped, they should be fine.
    Quote Originally Posted by colt45 gto View Post
    If you were told they were "belt-sanded" I'd be going over them every which way with a straight-edge to check them.
    As far as milling, generally they should be pretty damn smooth, with just the faintest tool marks.
    Depending on the application/head-gasket type, some shops will run a higher feed rate on the mill to give the head a bit more tooth to "grab" on the head surface - less of that going on, these days, but.
    Canaan NH
    I would never belt sand heads.
    owner since 2004
    cheshire, england
    i would claim for a new head if a machine shop belt sanded my heads, only a milling machine can get a perfect surface.
    Squivelicious Not Verified
    February 2004
    West Texas
    I used to rebuild heads in high school. Would belt sand before competitions.
    Turbo Timebomb
    Elkhart, IN
    Yeah, I'm sure the surface itself is not warped after the job, but it's the machining "grooves" I'm concerned about. I imagine if they are too deep, this will allow gas to escape and right into the oil/coolant passage they pass through, but I don't know. Like I said, it's not very deep, but you can certainly feel it w/ your fingernail and visually see them. This shop is always busy w/ work, so I have a pretty good % of beeing OK. I'm going to give him a call and see what he says about it.
    owner since 2004
    cheshire, england
    post a pic up ben
    Mine had these groves you speak of and they were done by a reputable shop also. I didn't like it at first but was assured it was OK. I haven’t had any trouble yet.
