Page 19 of 19 FirstFirst ... 9171819
Results 181 to 190 of 190
Thread: Base to VR4 Swap + Complete Restoration
  1. #181
    I lack color... verified
    Aug 1998
    The SRS grounds thru the wiring. No worries there. Same with the alternator too.
    Edit: Disregaurd that last comment. The alternator grounds thru the block.
  2. #182
    Thanks, I thought for sure the alternator did not ground through the wiring. Guess I'll strip those 2 and coat them completely.
    Learn how to Powder Coat at www.powdercoatguide.com.
  3. #183
    JNS Engineering verified
    San Jose, CA
    Sorry Greg but not true on the alternator. It definitely grounds through the block
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  4. #184
    Aug 1998
    My apologies. You are correct. Looks like I'm slipping....
    On some of my cars, I even added a ground wire.
  5. #185
    Thanks Jim. I was going to double check to be sure but I could have sworn it definitely grounded through the block. Thanks for the confirmation Jim. Really sad to see that you are selling your car btw.
    Time to get back into a 3S Greg. Those Miata's are messing you up!
  6. #186
    Aug 1998
  7. #187
    Replaced the bearing in the power steering belt tensioner. For those interested, the part number is Koyo 6301-2RS.
    More coming soon.
  8. The Following User Says Thank You to 99ishVR-4 For This Useful Post:
  9. #188
    Finally done with my power steering pump. Put more time into this than I care to admit. First I just planned on powder coating the end cover but after taking the pump apart, I decided to dot he whole thing. I originally had the type B power steering pump with the bearing pressed on the pulley shaft. Couldn't get it off myself so I took it to a shop to have them press it off. They bent the pulley and ruined the bearing. Went and bought another pump at the junkyard and got lucky that it was a type A pump used on 95+ cars. This pump has no ball bearing but instead uses an oiled journal bearing type bushing in the pump housing. This allowed me to coat the pulley. Purchased GATES 348840 rebuild kit from Rockauto. Put all the internals through the ultrasonic cleaner. I'm pretty happy with the way it turned out.
    Fresh from the junkyard:
  10. #189
    Does this mean you are keeping her!
    As always AMAZING results, keep it up man!
  11. #190
    Quote Originally Posted by Beef6 View Post
    Thanks man
    Yeah, I'm back into it again. I've been picking up a bunch of parts I needed. The list of stuff I need is still a mile long though so it's going to be pretty slow going.
