Results 1 to 6 of 6
Thread: Difficulty going into first gear
    Aug 2011
    Tampa
    Last month I noticed that it was difficult to go into first gear. Became more problematic until one day couldn't get into any other gear without double pumping the clutch. So, put it on the lift and checked the clutch master and slave. All is fine there and I have a braided slave line with new slave cylinder installed a couple months ago.
    Decide to change out the tranny fluid. Plenty of fluid comes out and is a dark brown. Refill with Redline MT-85 and take it for a drive. Can get into the gears now and all are fine except for first gear. I can roll to a stop and with clutch depressed, slip it in. However, if I just come to a stop, then try and go into first, I hit a slight wall and a little more pressure, can go into first. If I tap back towards 2nd (without going into 2nd), then forward to 1st, the gear slips in ok.
    Thoughts on how I can smooth out the engagement? Possible synchro is damaged?
    Thanks!
    Synchros aren't doing anything when you're not moving with the clutch depressed. Sounds like the synchros on 1st are acting perfectly normal, fairly easy to slip in at low speeds (synchros are doing their job here) and slightly more difficult to slip in when totally stopped (synchros are fighting you a little bit here because the gears need to rotate slightly to align). All cars I've driven act like that, and my VR-4 acted exactly like that. The few other members on here that drove my car can attest to my tranny being nearly perfect
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    ^Agreed. Does it in my Audi to if Im stopped and they arent lined up right, I either have to slip the clutch or let the car roll a bit..
    March 1996
    Charlotte, NC
    Sounds like maybe the dog-teeth on 1st gear and/or the 1/2 slider are worn. Synchros are not the only part of getting into a gear - they server to help line things up when everything is spinning, but it's ultimately up to the dog teeth on the physical gear and the slider to engage to actually "get into gear". If these are worn down nubbins, it becomes much more difficult to get into gear even at a standstill.
    EricB
    Eric "SUTHNR" Bowden's Garage
    * 1993 Dodge Stealth R/T - NG09 & NG14 Best All-Round 3S TWICE!! - NA POWA!!
    The 222 HP Stereo... The MOST modified slowest naturally aspirated FWD Stealth out there.
    * 2008 Toyota Tundra Pick'm'up Truck
    Mods: Right Foot FTW!
    * 2010 Toyota Corolla
    Mods: The Wife FTW!
    * My stereo site lives here: The 222 HP Stereo...
    * My personal venture:
    Edgy Elegance Photography - Weddings, Home Sales, Automotive, etc!
    * I love taking and creating Panorama Pictures: Check out my Panorama Gallery
    * The 3000GT/Stealth Collectibles Site: Ultimate 3S Collectibles Archive
    * Visit 3SX for record setting parts at www.3SX.com
    NG10 Pics LOADED!
    3SX 1/4 Mile Times
    3SX T2 FWD 3S 10.19 @ 140.31
    3SX T4 AWD 3S 9.214 @ 154.98
    Also T4 AWD 3S 9.339 @ 159.23
    3SX twitter | 3SX FaceBook
    Member
    My car does this also, If i'm at a stop and it wont go in I usually just put it in second and then put it in first. Always makes it go in smoothly.
    also would be a prime time to bleed the clutch again
