Here's the short, short version.
I'm doing a rebuild on this Spyder. While pulling the windshield trim ahead of a windshield replacement, I noticed a lot of rust in the channel that holds the weather strip.
ASC installs a metal 'cap' over the stub of the original coupe roof. That's the part laying on the windshield in the first pic. The gray wavy stuff is the glue they used to hold it in place.
This is the rusty remnant of the coupe roof.
It gets progressively worse going over to the passenger side.
So...do I grind it down as clean as I can and hit it with some rust converter? Or do I cut out the spot welds and replace it with a section from a coupe parts car?
Another pertinent fact. There's rust underneath this part where the bottom side of the Spyder-specific header bracket was installed. It's the part that holds the latches and latch motor, as well as the sun visors. Removing the outer skin would let me get at that.
