My car has developed a delayed start problem. It can take up to 10 seconds of cranking before firing. The problem developed over the course of about 2-4 weeks.
I have changed the spark plugs, inspected the wires, checked my fuel system, and lastly, done a compression test. The results were not good.
Cylinder 1: 95
Cylinder 2: 80
Cylinder 3: 95
Cylinder 4: 90
Cylinder 5: 95
Cylinder 6: 85
I have a '91 turbo. The service manual claims that ideal compression is 135 psi, and the lower limit is 115 psi.
Alex3000gt and I poured some oil into 2 of the cylinders to see if the compression numbers would go up. One had no response (remained at 85 psi) and the other jumped from 80 psi to 90 psi, indicating the piston rings were not creating a great seal, but that the valves could still be more of a problem. Surprisingly, the car still makes pretty decent power.
Are my compression numbers leading my car to take forever to fire up? (after these results I'm personally surprised that my car starts at all)
Any guess on how long I can continue to run before the compression numbers get so bad I can't start or my starter needs to be replaced?
Thanks for the feedback.
