Results 11 to 20 of 44
Thread: thoughts on crappy boost gauges
    AEM guages are about as good as it gets, and i think they are one of the best looking guages.
    And the list goes on...
    rawr. verified
    August 2009
    San Diego, CA
    Yeah, I have 5 AEM Gauges except fuel pressure. Wondering if I need it or not... Hhaha!
    https://car.social
    Advanced Tech? verified
    while we're on the topic of AEM gauges, do you guys have any experience monitoring knock with the AEM serial gauges? Do the gauges "hold" the maximum knock counts for very long or does it just flash and then disappear?
    I had prosports and they are incredibly worthless. Just installed some stack gauges, pics and review here
    i honestly think that the guy running prosport didn't have any electrical engineering experience. he very likely asked the chinese guys what he wanted in very vague terms, and they fulfilled his request very cheaply because he didn't specify any perforamnce criteria other than steady-state accuracy.
    I'd say you're right.
    I got the two gauges for a little over 100 bucks. They did something different for the opening ceremony, I thought they would do the same thing. They might be pretty to look at but to read them kind of sucks. I liked the autometer better. I guess I would have been happy with the fuel pressure one if it read correctly. I was low on cash so I just decided to give them a shot knowing I might be pulling them out before long. Very cheap = Very cheap.
    11 sec FWD! (old name: 94atxvr2)
    2004 ****Click my home page for videos*****
    Toledo OH
    I have seen rings blown on my friends car from his bad mechanical boost gauge. It was an autometer mechanical and he had no reason to assume it didnt read right. It looked like it worked fine but didnt read right. He was set at 17psi, with all proper fuel mods, according to his gauge. but after a couple passes at the track his rings were gone. When he got rings fixed, I let him try my boost gauge (another autometer pro comp I used for years) and we compared the two gauges.
    His autometer read 8 psi, mine read 17psi. Then his read 16psi when mine read 25psi. SO long story short is make sure your gauge is in working order. DOuble check it with another or a source that you know how much is being applied before going all out. And if something feels wrong make sure boost is right.
    A crappy gauge cost a whole engine rebuild in only a couple passes. And it was weird because he turned it up little by little but it still kept reading low so he thought it was okay. It barely went up and was still in pump gas territory. But it just went up alot slower than what was correct. He was running 17 psi on pump in his dsm on the bad gauge which was prolly over 26psi in real life.
    BTW it was a newer gauge so don't assume just that its a new mechanical gauge that it is 100% accurate. Bad stuff does still get pass quality control.
    Savannah, GA
    This is my option as well:
    Quote Originally Posted by Atrosity View Post
    I have all aem gauges, very satisfied with the results and accuracy of the digital gauges.
    David P. - Savannah, GA
    2009 BMW Z4 35i :: Mods :: Vishnu Performance PROcede ECU
    2009 Mercedes ML-550 :: Mods :: None but fully loaded with ever option
    1993 3000GT VR4 :: Mods :: Forged Block, APR Studs all around, Stage 3 Heads, Racing Cams, Adjustable Cam gears, TD05 Custom Billet 16G Turbos from DR, Custom Pre Turbo Pipes, 38x14x4 FMIC, 3inch custom intake, FUELAB Prodigy Fuel Pump and 2x filters inline @ -10AN, Fuellab Fuel Pressure Regulator with oohnooo hard lines, 1000cc Injectors, Custom Exhaust, Tial BOV, AEM EMS, AEM gauges (Fuel & Oil Pressure, A/F, Water Temp, Boost, & 2x Serial), 2x AEM A/F Sensors, 2x AEM EGT Sensors, Fidanza Aluminum Flywheel, SPEC Stage 5 Clutch, Steel front and mid transfer case upgrade, 2 Piece Aluminum Drive Shaft, Transfer Case Bracket, Quaife Front Differential, Kaaz Rear Differential, Super Car Engineering Center Differential, NOS Kit, 220 AMP Alternator, HKS Ignition Booster, All sensors replaced, EGR block off, Solid engine mounts, Tein FLEX Coilover, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff.
    FOR SALE 1994 3000GT SL :: Mods :: New 4 Bolt TT Engine, Stage 3 heads, Full turbo conversion (99 ECU), 6 Speed MR Transmission, 720cc Denso Injectors, 15G Turbos, 99 Flash ECU, 3.5 GM MAF With Translator, 36x12x3 FMIC, MR 6 Speed Transmission with Quaife Front Differential, Greddy Type-RS BOV, 3inch custom intake, Walbro fuel pump (hot wired), Tein FLEX Coilover, and other stuff.
    “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
  8. #18
    rawr. verified
    August 2009
    San Diego, CA
    Another reason why I will not buy Prosport.
  9. #19
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Man I have an STRI I guess I'm not that worried about response time but that is nuts! I have an STRI mechanical before the DSD and I think it was about the same as the DSD. I wonder why they are so slow.
  10. #20
    So should I stay with getting Defi or get AEM?
  • History
  • Information
  • Groups
  • Events
  • Resources
