Results 1 to 9 of 9
Thread: WANTED INTRAX SPRINGS for NON ECS 1997 VR-4
    The Panda Not Verified
    Washougal WA/Portland OR
    Looking for a set of intrax springs for my 1997 VR-4.
    Intrax Part # 55.1.013
    Rear spring # 47-020 (printed on rear spring)
    Bump! Any leads would be appreciated.
    Man vs 3/S verified
    Kingston, WA
    Good luck!
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    Good luck!
    why do you want intrax?
    Because they make a spring that fits the rear of a non ECS vr4 (96-97).
    you could just swap the rear upper strut mount to an "ecs" one and run any lowering springs.
    This is true! But the insulation top mount is not cheap from Mitsubishi. Plus it still won't fit the lower mount on the strut perfectly.
    Oct 2010
    96 Stealth TT/97 VR-4
    Couldn't you swap in some ecs struts, mix and match parts from you stockers with any other lowering springs? At least that was my thought as I was going to pick up some rear ecs cheap from ebay.
    I never did like the over sized eibach springs on stock non ecs rear perch - didn't know intrax made rears that fit. Thanks for the info.
    The Toys
    Quote Originally Posted by guido1205us View Post
    I don't like the idea of ECS shocks in the rear that I can't control.
