You're welcome!![]()
Drag racers run as cool as possible with their coolant but generally like motor oil up to temp. BTW they make oils that are good @ 130 deg F now. So if 130F is "up to temp" for you you're golden.
Look at any drive-along video with Tom Nelson. He puts beast mode cooling systems on his cars so cruising around temps are in the 150-170 range. A couple 3rd gear single block burnouts later the temps have hardly moved.
CAUTION- OPINION FOLLOWS
My car seems to have more 'pep' before the oil gauge registers 50C. I like to leave my car off as long as possible for my first auto-x run and hopefully by the starting line staging area I am < 60 deg C And no I am not wearing out my engine finding this out, either. 50k of oil analysis has shown that to be true.
However if you are trying to get 300k out of your 98 4 door LX Civic maybe you should just trust the MFR temp ratings and let it be.
What odd is all the other mitsu ROMs out there have the fans come on at lower temps. Even the turbo eclipse.
I wonder if you're right Nate and oil temperature is the reason Mitsubishi wanted this motor to run in the 200deg range. .
Well..Would've guessed maybe the clearances on the bottom end or the oil cooler thermostat perhaps, but factory clearances aren't much different than that of a DSM and I doubt that they would leave the fans so high just due to a thermostat for the oil cooler. Honestly, the only thing I can think of is perhaps they figured with the sidemounts ICs keeping heatsoak away from the radiator that they didn't need the fans to come on so soon?
Or, maybe they just came in drunk that day..Let's be honest, there's a few things that they did that just didn't quite make sense.
I think it might be more accurate or realistic to compare other V6 TT engines and not the brand (Mitsubishi). Comparing our V6 to a 4 cylinder is kinda apples and oranges. If we go the other way and compare to V8 engines we'll find the target being 210-220 as the normal operating target temp. My Toyota FJCruiser has a V6 engine and also is in the same temp ranges of 190-200 like the Mitsubishi V6. I suspect other V6s will also show to be in the same temperature ranges. My 6.2L V8 Yukon however is right at 212 where GM wants it to be.
Yes there are other applications such as pro drag and other specialty engines that run cooler but they are also designed that way from the start. The majority of people here having an overheating problem are still running stock engines mostly or darn close to it on the bottom end. So I was sticking to that as the parameters. Many drag racers also like their engine oil hot, but is still subjective. In the end are we talking about drag racing and performance or the average 3S user that wants to DD and change up their fan temps for some reason (overheating)?
So maybe it'd be better to compare V6s in general and see if the VR4 is the anomaly or if it is right in the same ballpark as other company's V6 designs and specifications? I don't think they (car mfg's) would all be wrong in their target temperatures. I am willing to bet they will all be in the 190-200 range.
Hmm..Well Nissan Frontier V6 (NA) was around 180-190 regular.
300ZX regular operating temp is...180ish as well I think. Been a while since I've been around one, and the one I was riding it was NA, not TT.
V6 Passat is around 190 as I recall as well.
