Results 21 to 30 of 36
Thread: Disassembly: Radiator Fan Control
    Sep 2012
    Decatur, TN
    Mitsubishi intended for the fans to be on at all times with the AC on. Problem is in the winter when you are trying to warm your windows with the defrost they kick on and it takes longer for the coolant to get up to temp thus your car takes more time to warm up.
    In the opposite direction, with out the AC on the other issue is with a FMIC your car over heats...
    Part of me wants to eliminate the thermostat and target 170 deg to see if that helps with knock on pump gas.
    Believe all that you would see is that the car would take longer to warm up. Setting the fans to a lower temperature or increasing the surface area for the radiator would do more to keep temperatures down than changing or removing the thermostat.
    I lack color... verified
    Aug 1998
    Quote Originally Posted by cjbyron View Post
    Because 160 is not the optimum temperature for the engine or even close. Too cold. Nothing mysterious on the why. I don't know if you are talking just about cars with a FMIC or stock or what. Either way, the normal operating temperature at which the tolerances and engine was designed for is in the 190Fs. I doubt you will ever keep the car in that 160 heat range anyway unless a really cold day out. At which time it would be a hindrance to drive around all the time so cold. But the point is that trying to maintain that cold (by turning on that fans so early) isn't going to gain anything. If it does anything it will be to overcool your engine below the proper operating temperature range. In the summer of course the engine will still probably override that low of a temp and only result in your fans running more often than they should.
    If your car performs and holds steady at around 190-200 with your fans on all the time that's great. I just don't see where it is advantageous to have them come on at such a low temp. I think differently I guess - if your fans cannot keep the car at the right operating temps as it was designed (short of a lot of big mods) then I'd look at a different cause or fix rather than trying to reprogram the fans to catch up sooner. IOW - the cooling system is probably in poor condition. The fans should be able to control the temps as listed in the chart and then engine staying within the designed operating range(s).
    As for the fix you mentioned by pulling a fuse - that is just going around the actual cause IMO. Not to mention what if you want AC on (because it is summertime and is when most cars complain about overheating).
    These cars never had overheating problems from the factory for all the years they were sold and the factory kept the same settings without any problems. It was only when they started getting 20 years old, poorly maintained, and modded with cheap parts that it started being an issue. First step in overheated car IMO is to check for scale build up (likely) and also look at what is being run for coolant (too much antifreeze reduces cooling).
    And as we both agree, get those radiator shrouds on there as well as the under car 'splash shield' which many cars do not have them on, especially the older ones that damaged the front AA and never replaced. All of those help direct the air properly and makes a tremendous difference in your cool system performance.
    Now higher mod'd cars that truly need a FMIC (many don't) is a different story since putting out an appreciable higher level of hp (say 500+) changes the game plan on factory cooling system design. For this thread I though you were mainly talking about stock or a little bit above like a few bolt on mods and under the 500ish range or racing applications. I maintain that the cooling system should match the engine needs not have to come on 30+ degrees colder than you want to maintain as your target operating temp. Yah know? Even on my race car I have the #1 fan set to wait until 185F until it comes on. Target temp is 192-198 which is just right IMO.
    Nice to have a little more control over the fans on/off no doubt. I just wouldn't look to that feature to work miracles in most overheating problems or plan for a 160 or 170 target temp as being a good plan.
    I just read a bunch of opinions... None of which answer my question. Why is it so bad to run an engine cool?
    BTW I already know that with the thermostat eliminated the engine still gets up to temp.
    When i get a phone call from someone on a cruise on a hot day and their car over heats, guess what I tell them to do? A lecture about the necessity of a FMIC isn't going to get them off the side of the road.
    It's probably worth mentioning that I don't run FMICs on my personal cars. Many people feel the need to so as such I'm presenting an option to work around the hole they dig themselves into.
    Aug 1998
    Yes people tell me this happens a lot with a quality aluminum radiator. I'm simply curious what the draw backs would be to running our engine so cool. Does it have to do with keeping the oil temps up?
  4. #24
    Sep 2012
    Decatur, TN
    In theory, even the best radiator on earth shouldn't impact warm up temps too much until you reach the point that the thermostat starts to open.
    Hmm..I would imagine that cooler temps could potentially increase wear, potentially things could be kept from reaching temps capable of expanding to proper clearances? Potentially worse fuel economy (although nobody drives a VR4 for the gas mileage). Hard to say for sure, there would be a variety of factors to testing it all out and accounting for variables to determine long term impacts of it. I would venture that it's probably a relatively minescule difference and could be tuned for anyhow, the heater not being as effective aside. Anything that triggers off of coolant temps would need adjusting.
    I am on both sides of this as I did lower fan settings for now, but I will probably put them back close to the original settings as time goes on. For folks running a front mount, the fan control can help for sure, but a coolant system flush, replaced with around a 70% distilled water to 30% coolant mix and/or water wetter would go a long ways, especially with a higher pressure radiator cap. But, I digress from the point. Impaired heater function and gas mileage are for sure issues with it, with the possibility of increased wear. Again though, that last one would need testing to back it up.
  5. #25
    Seattle, WA
    Well, what temp would you want to run your car at? How about 100F? 120? Do you WOT at 125F? Where is the optimum and best operating temp at? I say 192 (yes, that is my opinion). Seemingly this also matches what the factory settings are targeting or real close to it. The why is easy as already stated - the engine is designed to run at a certain temperature for obvious reasons. If not then why not have the fans on continuously and try to run the thing as cold as possible. Do you also go WOT before your engine has warmed up? The concept here is very simple.
    Plus as someone else already mentioned - unless you've pulled your thermostat it isn't even going to open until above 170 so having your fans running to the radiator at 160 will not do anything since the thermostat is still closed.
    I didn't know we were talking about an answer to someone that phones you to help them on a hot day with their car. I thought this was on a forum where other input and suggestions (or opinions) were part of the routine. As for an option to work around I think that looking at their cooling system health and removing scaled up radiator, putting shrouds back on, etc. is certainly a simpler and easier obtained answer than reprogramming the ECU. And even if so should still be looked at rather than working around with such 'fixes'.
    That tis all
  6. #26
    Aug 1998
    The reason the thought is rolling around in my head is a theory that cooler temps will draw more heat from the spark plug & combustion chamber and thus help reduce knock. It's just an idea I would like to test.
    Gas mileage isn't any concern as all you do is scale back the warm up enrichment percent table.
  7. #27
    Aug 1998
    That tis all
    You really don't have anything useful to add to this conversation do you?
  8. #28
    Seattle, WA
    Other than common sense? No, not really.
    Not sure why you have your panties all in a wad. It was nothing more than that (common sense).
    It isn't like the gasoline combustion engine is new or that somehow you know better than the factory engineers.
    Why you think otherwise is beyond me. Certainly no reason to become adversarial about it.
    But by all means, please continue.
    Dying ain't much of a living, boy.
    Josey Wales
  9. #29
    Aug 1998
    Why you think otherwise is beyond me. But by all means, please continue.
    Yeah that's what I thought.
  10. #30
    Aug 1998
    truly reverse engineering marvel.
    Why thank you!
