So I finally got around to getting my driveshaft fixed. I took my spare driveshaft and filled in the carrier bearings with Polyurethane. It took almost a week for it to cure completely. Last night I swapped out the two and took it out for a test drive. I am getting a lot of vibration at about 60mph. I mean it is vibrating my seat like crazy!!! I can feel it also at other speeds but 60mph seems to be the sweet spot.
No I have run this driveshaft before and didn't have the vibration issue, just bad carrier bearings. when I filled them in with the Poly I made sure they were square and centered. Now I don't have the thumping in the DS anymore but I don't know where the vibration came from. I am thinking that maybe I didn't install the spacers correctly. I installed the taller on the rear carrier and the shorter one on the front. Is that correct???
My spacers are a little worn down also "Rubber is falling apart". so I need to get them replaced.
