I purchased an AP Racing BBK and installed it this week. I installed and treated as new and bled the brake system immediately after I installed. I did the traditional two man pump the pedal. Well, I took the car for a test drive on tuesday and noticed the brake pedal was a little squishy. I took it out again yesterday and the same thing, seemed like the pedal was sinking a little farther. I asked Chris and Erron about bleeding the AP's and they mentioned you have to bleed those calipers from both sides, meaning bleed each row of pistons independantly.
Well, today I had a friend come by, Tom, and we re-bled the brakes. Now I have zero brakes. The brake pedal won't firm up and just keeps sinking to the floor. You can hear air rush into manifold when the car is off and when the car is running if you depress the brake pedal the car starts to surge and the boost gauge hunts.
If you pump the brake pedal it will eventually build pressure but if left undisturbed for 10 seconds or so if you try depressing it again it will sink all the way to the floor. You can hear air from the booster escaping and entering the plenum. I verified all the check vales are good and they're installed correcly with the stop pointed toward the brake booster from the plenum. Arrows on the tube are pointed correct also. I also took 4 different check valves and swapped them out with the one from the brake booster. Got the same result so I don't think the problem is the check valve.
There's no active fluid leaks and when you hit the brakes with the car off the pedal still sinks to the floor which leads me to believe fluid is bypassing and is making me think the master is bad, but I don't know, I've never had one go bad so??? I have a spare I'm going to throw on but I can't confirm wether or not it works. Is there some sort of bench test I can perform to check it before install?
As far as priming the replacement master before install, do I just lock it in a vice and run hoses from the ports back to the reservoir and push on the main rod with a screwdriver till it stops bubbling? Any tips on prepping a replacement master would be splendid.
BTW, I pulled the entire brake booster and master assembly. Hopfully someone has ran into this and can help me out!
Need help, no brakes!
