Results 1 to 7 of 7
Thread: Car doesnt always start
    I'm having an issue with my VR4 where it doesnt always turn over and sounds like a dead battery. I can usually get it started after it does this by continuously turning the key over and over until it cranks. If I hook up jumper cables when it doesnt start right away, it starts.
    I know I know, sounds like a battery problem. I took the car back to sears to have them test it. They hooked up their computer thing to it and said nothing is wrong with the battery. It happens sometimes after I have the driven the car a short distance, but not every time.
    Is this a battery issue that the sears mechanic couldn't see because the battery recharged on the way over there or is there something wrong with the starter?
    95 3000gt VR4 - Somewhat still working
    92 Stealth RT-TT - Dead, Donated to Charity, Crushed
    94 Miata M-Edition - sold
    07 Z4 M Roadster
    Fowlerville, MI
    Does it click? Does the dash go dim/turn off when turning the key to start?
    If you turn the key over and over and eventual starts, it sounds like a click start fix. I'd try jumping the relay under the hood. This won't cause it to start if the key is out, but it will turn the starter.
    It does click and the dash does dim a little bit.
    What relay?
    Fowlerville, MI
    In the fuse box under the hood, there's a relay marked 'starter'. You can pull that and jumper the starter wire (one on the right when looking at the vehicle from the front IIRC double check this) to a 12V source (battery) to force the starter to turn. If you're not getting a signal from the key to activate that relay, you have the usual culprit of a broken wire/ign switch.
    http://www.supercar-engineering.com/...Fix/index.html
    Stuper Moderator
    January 2003
    The click start fix is good(you're welcome ). However, it very well may be your ignition switch. The tumblers get wore down over time. Your symptoms are very common for these cars.
    Douches
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    click click start IMO. Definitely worth following the SCE link posted above regardless.
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
    That sounds exactly like the problem I'm having. Thanks guys.
