Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: The CORRECT aftermarket PCV valve
    2004/5?
    SW Connecticut
    Just got a new valve from cherry hill because I figured hell, mine's old lets replace it. New one leaks a little, old one doesn't!
    Andover, MN
    PCV is supposed to leak a little bit, if your old one didn't leak a little bit, you weren't providing enough crankcase ventilation.
    Quote Originally Posted by Boost4VR4 View Post
    Huh?
    A "leaking" PCV implies that it will allow boost to flow into the crank case. Not at all what it should do.
    2004/5?
    SW Connecticut
    From what I had thought (hear-say), they should leak under high pressure only. My new one leaks when blowing into it while the old doesn't. Would that be considered "high pressure"?
    I'd be happy to learn if I'm totally wrong
    Forum User supporter
    Bounemouth, UK
    I have Krank Vents on my new build, on tick over there is so much vacuum that I can only just remove the oil filler cap (Blitz) & it nearly sucked the rubber washer into the cam cover.
    Jeff
