got em
got em
kyb shocks with eibach springs (lowering springs). Barely used. $300
Current:
2004 ML500 - Mommy Mobile
1995 3000GT VR-4 - lawn gnome
1999 3000GT SL - 7,436 miles
FOR SALE:
how much are these going to lower the car?
im not realy looking to lower it much if any
fuel sending unit - Assuming you are referring to the entire fuel hat and pump assembly as the sending unit is part of it.
coil packs (engine is a '95) - Coil packs are the same throughout the years.
rear struts are pretty bad - The ones Emilie posted will probably be your best bet and are very well priced.
Those springs won't slam the car to the ground. They clear up some wheel gap but I think they are .5-1" lowering springs.
sorry if i seem dumb. i am new at these cars and have pretty much owned and worked on trucks most of my life.
guess i should clarify. the actual pump and sending unit are ok. amzingly the car is running well for what is wrong with it. i was getting a gas smell in the car so i pulled the cover by the spare and can see that the hat is VERY rusted and wet looking and the line had been patched with epoxy. that is the story with that. i thought it was all one unit.
definatly apreciate the advice!
ok then these struts seem to be my best bet. do you have the sending unit or just the top if that is the way to go? ease of instalation is also a plus!
The fuel hat assembly is one whole unit:
If its rusted and the hard line is busted best to replace it. Emilie will have some in stock also. "They have everything....LOL"
I have a set of coil packs. I could let them go for $30 plus shipping.
I will check for an ABS pump (I am sure we have one), and verify we have a sending unit set aside, and I will PM you in a bit. I'm just eating lunch now.![]()
