Results 1 to 10 of 18
Thread: Fuel cut sucks.
    Runs on alcohol. The car does too. Not Verified
    San Francisco, CA
    Fuel cut sucks.
    I just ate the steering wheel. I had fuel cut set for 21psi and made that by 4500rpms. Was not expecting that.
    I'm making some really good power with a great powerband but she is getting a bit noisy.
    Making 15psi @3500rpms and over 20psi @4500RPMs.
    AFRs pegged at 12.0, timing around 16 degrees on E85.
    Raw knock of ~3v. I'm getting nervous about that, but I do have a built engine and solid mounts. Any AEM guys have comparable numbers?
    AEM s2 EMS | E316Gs | E85
    Player Hater of the Year
    San Antonio, TX
    Hahaha, man its been so long since I've had fuel cut
    Fuel cut sucks
    Yes it does, scared the shit out of me 1st time it happened.
    Forum User supporter
    Bounemouth, UK
    It feels like someone hitting the car with a sledge hammer.
    Jeff
    I lack color... verified
    Aug 1998
    I just had a thought. It'd be very easy to rescale fuel cut in the stock ecu to be PSI based instead of Load based.
    I thought I smelled smoke...jk go go go
    GREASE BUNNY
    VA
    I was so pissed the first time...pulling out in traffic.
    Stuper Moderator
    January 2003
    These engines are a bit noisy to begin with, but 3.0v is definitely at the point of concern. How much timing at peak tq and redline?
    Douches
    Jan 2011
    az
    you have enough pump for e85? i could have sworn i seen your car in the jackhammer dual pump hanger video i have lol. i want run e85 as well but u cant really read knock which scares me even with a built motor. and i already have the injectors for my setup which kind of sucks cause im only gonna b on the arc2. so your out of fuel?
    Quote Originally Posted by keo92stealth View Post
    Yes you did, I guess that's the 2nd time that car has had an acting job lol.
