Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Disassembly: Ignition Trim Tables
    N8RZ VR4 - 19THL VR4 supporter
    Jan 2011
    Brentwood, CA
    Any info on adjusting the ignition coil dwell settings to get a smoother power band?
    1991 VR4 - TD04-19THL, DR Stg3 heads, All forged lower end, Adj. Cam gears, Boost Exh. cutout, Walbro 341 HW'd, 720cc inj., AEM FPR, Hallman MBC,
    Clone ECU and Chrome V2 - Tuning for 20-PSI on 91 Pump at the moment
    St Joe
    What is the load axis unit? MAF or kPa? Thanks for the clarification.l
    I lack color... verified
    Aug 1998
    MAF pulses * MAF size
    St Joe
    Thanks Greg,
    Is there a good way to translate Maf load into a speed density load? ie PSI
    Edit: I've uploaded an excel spreadsheet of the data in a more "speed density format", with 3D maps included. please look over the data, I've done what I can to make sure I entered it right.
    Attached Files Attached Files
    Aug 1998
    No there isn't. Pressure will always change depending on air volume. The MAF measure air volume. A pressure gauge is just resistance on a pipe. This changes depending on volume, temperature and barometric pressure.
    Neither have a direct relationship.
    Hello Greg, I 've recently set base timing and noted timing retards as rpm increases when locked (due to delays in the transistors etc).
    Is there a "trim" for this to make sure commanded timing is actual timing at higher revs?.
    Also do you know if the timing reported by the OBD port is shown with all the trims already applied?.
    Cheers, Keith.
    Aug 1998
    Quote Originally Posted by KeithMac View Post
    It's caused by CAS latency. There maybe a trim but I never owned a 91/92 car so I never went hunting for it. Most guys just adjust the big table to match.
    Yes. What you're seeing is the final output.
