Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 72
Thread: Lets talk gauges
    Stuper Moderator
    January 2003
    Beyond what else has been said, I'd highly suggest p/h/w function in whatever gauges you get. When racing, you damn sure can't be looking at 5+ gauges. The one that was most important to me was WBo2, so I put it in a simple cup style pod on the top of the steering column. The gauges in the dash I had warnings set up so as not to have to be looking at them.
    Douches
    I know that answer was about as convoluted as it could be...
    Let us know when you've come up with a plan and we can discuss it further.
    Yeah - I may just get a spare a-pillar piece and mount the pod, anyway, for now - problem is that I'm installing a 1 1/2 DIN HU, and it screws up the available space there for additional gauges.
    I'll have to do more investigating vis a vis the flashable, too.
    Good ideas, Jeremy - won't be racing, but warning capability is foregone.
  4. #24
    Avoca, NY
    I have the Stri DSD series and love them. They're affordable, have all the features you need, look good, and are accurate. Defi is of course probably top of the list. AEM makes quality gauges all around, not just wideband.
    If you're interested in a set let me know and I can get you pricing.
  5. #25
    Quote Originally Posted by Maximal View Post
    I'll keep that in mind, Terry - thanks.
  6. #26
    Jun 2011
    Sweden, Gothenburg
    Quote Originally Posted by Valhallaz View Post
    I've got boost and afr on the pillar, oil press, water temp and oil temp in the center. I can check volts from either the turbo timer or the palm logger.
    I cheaped out with the 60mm v2 stri's. They appear to be acurate, and no issues in a bit over a year. And IMO, 60mm just fit the center holes (and my eyesight) better.
    At some point I'll pull them and blacken the bezels.
    Yeah, yeah, the vents are dirty...
    cheaped out? those are not exactly cheap imo at 180$ a piece.
    Anyone can recomend a cheaper brand?
  7. #27
  8. #28
    Glenn, you said you basically just pushed those 60s in for a tolerance-fit?
  9. #29
    Prosport are trash.
    They are accurate, but their motor is a damn snail compared to other gauges.
  10. #30
    Yeah, the 60's just shove in.
    IIRC, with 52's, if you retain the black plastic ring set from the original gauges, you can shove the gauges through the dash and then through the plastic ring set and they won't move. I have 52's in the stock spots in the dash.
    That said, the 60's definitely look better.
