Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Disassembly: Knock and Octane code
    Aug 2011
    These calculations are only for 98/99 ECU's, correct? Because I am pretty sure I've seen knocksum tables from the other site back in the day (that Mjannusch compiled maybe?) where a knock count up to 5-8 didn't affect timing. I also remember Jeff Lucius saying something similar, that small counts of knock were basically disregarded from the ECU.
    The prior ECUs were a little different, but still VERY similar to how the 98-99 stuff works. Any knock count affects timing, but it isn't until you get to 6 or higher that it starts hitting the octane counter, which starts to push you down onto the low octane fuel and timing tables.
    It's basically a timeline like this:
    1G DSM ECU - extensive hardware filtering
    Pre-OBD 3S ECU - mix of hardware and software filtering
    OBD 3S ECU - extensive software filtering
    Evo 7 and later ecu - almost entirely software based
    Around 96-ish, Mitsu started to go to common logic across all their engine lines so that everything used the same electronics and software. Prior to 96, everything was a mish-mash and mostly platform-specific.
    Dallas TX
    Thank you for the clarification Jeff.
    Greg, can you elaborate on how the triple/single gain get added in? More importantly, how they affect the knocksum sensitivity.
    Currently I have :
    single 8
    triple 30
    stock is
    single 6
    triple 28
    Thanks!
    I lack color... verified
    Aug 1998
    I've kinda avoided posting too much detail on how the system works because I don't want people blowing up their engines. It takes a trained eye to understand the difference between engine noise and real knock.
    I had to raise the triple gain on your car because your engine noise levels would creep above the knock base threshold. This threshold kinda works similar to a fuel trim where there is a base factor, correction factor and anything above that calculated noise level is considered knock.
    As the engine makes more power (or just ages) the noise level gets louder and louder. The code is setup to monitor this noise level. Eventually though, it comes to the point where the ECU can't compensate anymore for the noise level and thus you get false knock.
    Your engine being fresh wasn't too bad in terms of noise level but I still had to raise the triple gain to get some leeway in the upper RPMs. That's why the increase was done.
    Remember us logging the raw knock voltage and looking at the graph to determine if the noise spikes were real knock or just engine noise?
    Yup, I just wanted to make sure the numbers I have make sense now. We did that a while ago and I remember changing it at the track at the NG. Just wanted to make sure I wasn't copying over bad values from an old config or something that I accidentally changed.
    Thanks!
