Page 9 of 33 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 322
Thread: I want this plenum... anyone know who made it?
  1. #81
    Sep 2012
    Decatur, TN
    I've often thought that the intake could benefit from a larger plenum area, curious how it works out. Hell, larger plenum with factory length runners could improve things, let alone shorter runners to change power band.
    Other throttle body options would be maybe a Mustang or LS1 throttle body around 75-80MM in diameter, I see a lot of stuff hanging off the Q45, not sure how much can be blocked off and cleaned up that isn't necessary. Certainly intriguing, will be interesting to see what comes of it and how it shifts the power band.
  2. #82
    Corunna, IN
    I have an N/A plenum disassembled. Not seeing myself ever put it back together either.
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
  3. #83
    They have a Na lower plenum there, or they did when they fabbed the bungs for my meth.
  4. #84
    I can get one, and swing by there in the next few days if you want.
  5. #85
    Sep 2011
    XG350 runner with true 90mm TB vs stock vr4 runners and custom tank on 75mm tb. The runners are larger in diameter all the way down and then they tapers down to stock. Also the runner is taller than stock so it hit the hood.I'm trying to find out if I can machine the upper intake or the lower intake so it clear the hood better. I could still close the hood but I'm afraid it might crack a cf or fg hood if I close it the same way.
  6. The Following User Says Thank You to mehrshadvr4 For This Useful Post:
  7. #86
    nice! keep us posted!
  8. #87
    Banned J. Fast's Avatar
    Do it... And let's setup a group by for two styles. Drivers side and passenger side!
  9. #88
    Quote Originally Posted by mehrshadvr4 View Post
    Great experience right there bro! Is that their 90mm throttle body option or someone else's? How long are the runners?
  10. #89
    What throttle body you lookin to run?
  11. #90
    Depends on whats available. See if they offer options. I'm thinking an 80mm or 90mm. If they don't have an all-in-one package with TB and Tank we can look into using the CX Racing 80mm billet Q45 TB or their 92mm billet GM TB. Both are $300. I was hoping they offered an all in one with port matching and 90mm throttle body like mehrshadvr4 depicted.
