Page 18 of 33 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 322
Thread: I want this plenum... anyone know who made it?
  1. #171
    I'd like a bigger plenum for my car too. I have an extra lower portion already incase I ever wanted to port it. In regards to the dimanted 80mm one, couldn't you just run each side down a band saw? Cut the throttle body housing off the right side, and the cap portion off the left, swap sides, reweld on? Then you wouldn' thave to mess with the runners at all.That may be the cheapest bang for the buck option out there. Then port the lower stock portion to mate up with the slightly larger dimanted openings.
    Built motor, DR750s, AEM and Meth
    http://www.802projects.com
  2. #172
    Crimson Jihad Not Verified
    That tank does not look all that much larger, and the runners appear to be about the same as oem. Any measurements on it?
    Only thing Dave posted was that it was from another Pampena built car (italograsso which made 900+), and that he ordered it from GCtech. I messaged Gil on facebook to see if he could share some info, or maybe build me a manifold using a NA runners with a largers better flowing tank.
    CAUTION: Over Boosting May Cause Accidental Orgasm.
    1993 Mitsubishi 3000gt VR-4
  3. #173
    I don't bite
    Southern IN
    Why mess with waiting for years when you can order the XM manifold that looks to be as good or better design for $500??????
    Anyone that's wants a mani with little to no loss of low end with a nice increase in power won't find a more cost effective manifold unless they have the ability to make it on their own or have a "hook up" with a fab guy.
  4. #174
    Is the XM Manifold thing really happening? I thought they needed 10 people. Could we just buy their diamante 3.5 tank with a q45 flange and weld it to an NA plenum lower half ourselves?
    Also I found info out about the diamante intake. 69mm TB opening, could be bored out a little more, but it's a lot bigger than stock. Someone cut the ends off and swapped them like I was talking about.
  5. #175
    August 2010
    Chicago
    looks nice but we need some data to back that up...
    Found some more...This car is using a stock hood...looks like it shouldn't be *too* hard to replicate..?? Almost looks like the one above but with shorter runners and a bigger tank
  6. #176
    August 2010
    Chicago
  7. #177
    August 2010
    Chicago
  8. #178
    Badass3000's looks very similar to the DR. Maybe an early product?
    Also, this car (w/ DR installed) I believe:
    Darryl?s 1991 Mitsubishi 3000GT VR-4 | The Performance Factory
  9. #179
    August 2010
    Chicago
    I originally thought it was....not sure though. Runners seem shorter
  10. #180
    Quote Originally Posted by NOMIEZVR4 View Post
    Haha that is how I was going to run my meth before deciding to hide it...
    The XM Mani will happen, just will take some time due to the delays in my build. If I were gremlin free, and could dedicate time solely to it, answers needed would be had.
