Thank-you, sir. Much appreciated!
Hey, anything to reduce the number of flashes - I'm all for it.![]()
I've never stressed too much about the number of flashes. There's over 100 on mine and I've never had an issue. It even started life as an sl ecu, so the cpu may be originally from 1999.
I did pickup a spare sl ecu just to keep with me if I go road tuning. I don't know if I have just been lucky or the bricked thing is user error most of the time.
You probably should lower the tps closed loop delta tps percents to start with. The stock map waits too long to go to open loop.
Sent from my RM-845_nam_vzw_100 using Tapatalk
Originally flashed 560cc with low latency really bogging low and mid rpm ranges getting cel P0300 random cylinder misfires and running too lean 15-17 afr.
Then flashed 513cc with high latency no cels running 13-15 afr but low rpm load bogging
Today flashed 450cc with high latency ran way better at low and midrange rpms with just a very minor hint of bogging got cel P0170 and P0173 Fuel Trim Bank 1 and 2?
All trims ended up at 150 each
Car has started and idled well within reasonable limits in all the above conditions. BTW may not be relevant but the speedometer goes to 20 mph and then drops to zero and stays there. Do these functions depend on the speed sensor?
Forest, Jim, Alan, Greg or anyone that can help me figure this out. It made no sense that flashing 450cc runs better on 560cc injectors.
At least now I can drive the car to the store and back to feed myself lol
Forest, the reason I used your quote is that it is an example of some of the things I know nothing about or how to change them. Obviously, you guys know way more than I do.
I am continuing to educate myself in these matters, thanks for your opinions.
