Page 2 of 21 FirstFirst 123412 ... LastLast
Results 11 to 20 of 209
Thread: TD04 Hard Pipe and/or FMIC Surge Issue Thread
    iowa
    would putting some holes in the seperator plate help to balance it kinds like an h pipe on exhaust? i also think a carefully placed balance tube would help a bunch you would almost want to mimick the design of equal length headers . to get the pulses to mead like you want. so with that thought would measuring out the length differences in the pipe and starting with the shorter one put the balance tube bung towards the end and the long one put the tube at the previously measured length from the shrot one? just a thought maybe im full of it . in essence placing the balance point equal to both pipes would be mimicking an equal length setup sorta.
    I'm putting on a ballance tube. I'll post up results when I get the car back on the road.
    Though speed density may eliminate this issue, I ultimately will be doing a flashed setup for oem drivability.
    Great info, keep up the ideas guys.
    Madison, WI
    going to hard pipes gives you compressor surge with 9b's?
    San Francisco, CA
    Quote Originally Posted by STiedVR4Guy View Post
    Hard pipes alone can cause it, but generally speaking it's more prevalent with single-core FMICs. But yes, even 9bs have this problem.
    AEM s2 EMS | E316Gs | E85
    Never finishes any verified
    Wake Forest, NC
    I was really worried about this when I installed my CX Facing FMIC kit. I'm up to 14 psi now and I have no surging at all.
    I wonder it is has anything to do with the difference in the design of the DNP kit compared to the CX racing kit???
    The merge collector pipes are vastly different on the two kits, So is the length of pipe going to the front turbo! DNP is underneath were as CX is on top, correct!?!?
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  7. #17
    Man vs 3/S verified
    Kingston, WA
    A couple of my lower pipes are the factory rubber, no surging. Hks sides, 9bs.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  8. #18
    Madison, WI
    I have DSM side mounts ready to go in. So this will most likely not be an issue as they meet up at the ypipe? (I don't have hard pipes yet but I plan on getting them)
  9. #19
    Advanced Tech? verified
    going to a larger volume 4" intercooler helped on my car with 15g's. I don't quite see how going SD would help because this is a problem with air pressures bouncing back and forth, not a problem of air flow/pressure measurement.
  10. #20
    no surging problems with the smics and DN hard pipes with the ends chopped off ,2" piping all the way
