I looked at the calendar this weekend to pick a date and I just knew what date it had to be....
April 1st
How does 1:30pm to everyone?
http://mi3si.org/gatherings/events.php?neventid=57
April 1st
Pending on location I might be a little late. What did you have in mind?
Sounds good to me!
I will be there!
Mongo again?
Unless someone has a better suggestion.
Sounds good, I'm bringing a coat this time just in case.
good call.
Its the lansing gathering it can be anywhere between 20 and 80 regardless of the month we have it.
I'll make the drive up.
'92 Stealth ES
'95 Stealth R/T
'93 3000GT VR4
Should be able to make it. Milkman, if you want to meet up with me and travel up together let me know, you will go right past my place if you are coming up 69.
