Up for sale is my eManage Ultimate setup. It took me a long time to piece this together and I planned to stick with it for a long time but I decided to change setups (surprise! lol).
Includes:
eManage Ultimate Unit (bought for $600)
Boomslang Stage 3 Plug and Play Harness for 1G (bought for $210)
GReddy Pressure Sensor with Harness (~$100)
GM Boost Control Solenoid (~$50)
Nice Wire Sheathing
Scanmaster 3 with all extras (bought for $250)
Injector Adapter to Eliminate CEL from Stage 3 (~$100)
The only wiring you will need to do is provide a power source for the solenoid under the hood. Everything else is already there I paid around $1,300-$1,400 for this setup PLUS all the work I did setting it up/wiring it/etc.
This setup can control airflow, timing, injectors, boost, two step, etc. Works AWESOME. I had a map optimized for 9Bs at wastegate and at 15 PSI, just swap maps and you have new fuel, timing, and boost settings. You can also tune RPM v. boost so no retuning everytime you change boost
Also, I set this up so you can put the eManage unit under the passenger seat and run the wiring under the center console to the ECU for a clean install, yet you can also plug in the laptop easily
I am looking for $1,150 for this setup paypal'ed and shipped. Great deal!
Let me know if you have any questions.
