Results 1 to 10 of 11
Thread: Where can I buy one of these?
    Raleigh, NC
    I need to replace this connector due to the clasp breaking on the firewall side of the cable. I replaced the cable that connects to the starter, but it comes loose all the time to prevent my car from starting. I would like to keep the stock connector setup if possible. Let me know if you need any more details.
    Moving on to reality. Sold my 3KGT, and now I am selling off my parts.
    Click here to see my parts for sale
    Jan 2011
    az
    your probably are going to have to find somebody that is willing to chop up a harness.
    Never finishes any verified
    Wake Forest, NC
    Just cut it off and get a set of wire terminals from radioshack. I cut mine off years ago.
    Even if you found a replacement one it would be as old and fragile as the one you have now......
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Junkyard. Mine is on a 92 and still works like new so its not like they are all fragile. Just make sure when you splice wires that you SOLDER and heat shrink wrap the connections!
    Forum User supporter
    Bounemouth, UK
    Quote Originally Posted by vroom4 View Post
    Or just put the conector together and heatshrink the whole conector.
    Heatshrink comes in all sizes, once you have done that it wont come apart unless you cut the heatshrink.
    Jeff
    You'll have to source a parts car for it. OEM doesn't sell many (if any) pigtails anymore.
    Raleigh, NC
    Anyone have an idea of what gauge the wire is? The reason I am asking is because I found this... Connector
    Quote Originally Posted by blackrob View Post
    Should be 16 gauge.
    94 3500gt vr2? verified
    NC
    There's a ton of these on the car. Probably some that aren't even used that you could just cut off. That's the same connector also used on either the power window or power seat motors. I have one of these and one of the other common 2 pin connectors cut and ready for unexpected situations and I've needed them both a few times already. I keep them with my jumper cables, tire patch kit and stuff like that. These 2 spare connectors along with a 9v battery allow me to move a power seat forward/back or roll a window up/down on any 3/s with no power for whatever reason
    Anyway if you need one, I have several of them on extra harness segments (I'm an hour away). Or you could check with Gonzo, he's up your way.
    Or you could go spend a few $ at radio shack or walmart on these and wire up your own.
    ziptie.
