Need to add knock sensor and o2 sensors
Post via Tapatalk
Post via Tapatalk
Wtf happened to yer old ones? You burned the block or sank it Texas style?
I have them, rather put new ones in.
Post via Tapatalk
I dunno, id keep em, they're easy to diagnose if they are faulty.
See anything else missing Colin?
Post via Tapatalk
Get a tube of liquid gasket for the oilpan.
Front and rear main seal.
Thats really all i can think of for now.
That little white noise condenser thingy that bolts on the coils (since you're swapping PTU+coils)
Noise Condenser by Coils 3000GT Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
Nice list so far.
Post via Tapatalk
So far, this is what I have noted down.
Krank Vents
Coil Pack*testing mine first*
PTU
Exhaust manifold gasket x2
oil pump gasket
water pump gasket
2 head gaskets
accessory belt
timing belt
tensioner adjuster
tensioner pulley
idler pulley
water pump
oil pump
upper + lower intake plenum gasket
thermostat + gasket
valve cover gasket
spark plug gasket
cylinder head bolts
oil pickup
knock sensor
front + rear main seal
Noise Condenser
front+rear o2 sensor
crank pulley
alignment dowel pins heads
oil feed+return
Replace the coolant hoses to the inside heat too if they look all crappy like mine did, guess it hasn't really have to do with the block though![]()
