Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: My Longblock Build. Questions inside. :)
    I wouldn't even want to chance that. Head bolts are change in the jar.
    Runs on alcohol. The car does too. Not Verified
    San Francisco, CA
    FWIW I'm doing a build right now and this is what I buy:
    A good upper engine kit with MLS gaskets and VSS. Covers most of what you need. Like this one:
    91-99 3000GT / 91-96 Dodge Stealth Engine Upper Gasket Kit | eBay
    OEM water pump
    OEM oil pump
    OEM timing belt
    OEM tensioner pulley
    OEM tensioner
    Generic belts otherwise
    Other (non-timing-related) pulleys are maybes depending on condition.
    I reuse the oil pickup (new gasket of course) and head bolts assuming the car was previously healthy.
    AEM s2 EMS | E316Gs | E85
    Does the oil pickups change through the years? Or can I use my 92 2 bolt oil pickup on a 95 4 bolt block?
  4. #24
    One fix at a time verified
    Kansas
    it can be. I probably made 4 orders to mitsu as I went along. There are a lot of little things that end up being in rough shape, but you can't really tell until you put everything back together or have a lot of experience.
    I've sure spent a lot of time watching paint dry.
    Agreed. It's all the little stuff that either nickels and dimes you to death or severely delays getting the car back together. I always run into that doing an engine build or anything complex for that matter. It's almost good to replace what you can while you're in there so you don't have to worry about it but I get carried away very easily doing that.
  5. #25
    I just made a list taking the engine out of stuff I wanted to replace so I could order it right away and it didnt delay anything. Stuff like balljoints, axle boot, electrical connectors that got damaged, little metal c clips, check valves etc. It does add up quickly to 6-700$ though if you buy new.
  6. #26
    Intopy, dont use that gasket set! use the factory stuff. you will have coolant push etc with those head gaskets. you guys should always use the mitsu stuff.
    the block is not going to have a rear main seal assy in it. make sure you spend some time making sure you have a perfect pickup with no bent support and make sure you have plenty of pan clearance all around the pickup
  7. The Following User Says Thank You to Ray Pampena For This Useful Post:
  8. #27
    San Francisco, CA
    Really? Even for stock rebuilds?
    I'm pretty sure I've used those MLS gaskets before with OK results before, but the last time I didn't take your advice it certainly cost me lolol.
  9. #28
    Quote Originally Posted by Intropy View Post
    haha on a stock rebuild maybe.. i wouldnt want them on something that gets pushed at all. nothing worse than having to take it all apart.
    how are all you guys been down there?
  10. #29
    I guess I should find myself a good manual with the installation process and/or at least torque specs hahaha
  11. #30
    San Francisco, CA
    Quote Originally Posted by Ray Pampena View Post
    Good... well, I can't speak for everyone, I ended up moving to LA the end of last year. Car is doing great now that I tightened up the mains and run only OEM oil filters.
    Oh yeah, add that to the list. OEM filters!
