Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 71
Thread: My Longblock Build. Questions inside. :)
    VR-3747 :D Not Verified
    Dayton Ohio
    the water pump comes with a water pump gasket, i am saying this because i ordered them seperate, and now have an extra gasket. you will want cam gaskets, and VSS. there is a throttle body gasket, water gaskets, copper o-rings for the turbos, the turbo o-ring itself (bigger, like 1.25" diameter), new rear main seal, new gasket for the egr, o rings for the fuel injectors, and probably 50 more things if i had the time to sit and think about it. those come off the top of the dome though.
    Did I miss something, why not order a whole gasket set? I used 99% of them on my longblock rebuild.
    I am a newb to this but building thing, but will I need a rear main seal if the short block is new?
    The heads are already assembled along with the short block. I just need to put the two together.
    see if your builder installed the seal or not. Look at the crankshaft flange.
    I will have to look at it when I get home, but Pampena was the builder. (for future reference)
    Forum User supporter
    Bounemouth, UK
    I am still trying to figure out what a spark plug gasket is.
    Jeff
    4 gaskets in valve cover probably.
  8. #18
    I think they spark plug gasket does come with the valve cover gasket set.
  9. #19
    Bounemouth, UK
    Quote Originally Posted by vroom4 View Post
    Of course, LOL
    Jeff
  10. #20
    If you want to save some money you could check to see if your head bolts have stretched at all. I have never replaced them(on any engine) after verifying the threads in a die and never had headgasket problems.
